Bearing replacement, seal orientation...???
Old Nov 18, 2013 | 01:47 PM
Airborne173rd's Avatar
I'm doing a bearing replacement and complete break job, 89 xtracab 3.0, 4x4 5 speed. Wasn't really paying attention when I pryed the hub seals out...I'm wondering which way the seal goes back in, with the tension spring of the seal towards the outside of the hub or the inside. All help appreciated, thanks!
Old Nov 18, 2013 | 01:49 PM
Or to make it easier, the spring facing the tire or the front diff.....
Old Nov 18, 2013 | 02:03 PM
millball's Avatar
Spring faces tire. Flat side of seal to diff.
Old Nov 18, 2013 | 02:06 PM
It appears both sides of the seal are flat. They are timken seals btw...
Old Nov 18, 2013 | 02:09 PM
millball's Avatar
The side with the spring can't be flat.
Old Nov 18, 2013 | 02:14 PM
The side opposite the spring has a raised rubber portion that sits slightly higher....
Old Nov 18, 2013 | 02:21 PM
millball's Avatar
In any case, the spring side goes toward your freshly greased bearing.
Old Nov 18, 2013 | 03:10 PM
Thanks a million!
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
andrewtexas123
Jul 14, 2015 04:29 AM
