Auto to manual hubs?
Old Dec 7, 2013 | 11:47 AM
Finally4running's Avatar
What year manual hubs can i use to replace my '88 autos? The hub release spring is broken in one and I'm trying to decide to fix or swap.
Old Dec 7, 2013 | 11:56 AM
Cyberman's Avatar
Any ifs manual hub will work.
Old Dec 7, 2013 | 02:37 PM
wyoming9's Avatar
Red face
Just remember to get the extra nuts and locks to hold the hubs on the axle
With only one nut they tend to come loose and make a mess.
Old Dec 7, 2013 | 04:01 PM
bone collector's Avatar
local junkyard..... MUCH Cheaper
Old Dec 7, 2013 | 04:03 PM
JasonYota's Avatar
X2 also check Craigslist and other classifieds around your area
Welcome from Alabama
Old Dec 7, 2013 | 04:33 PM
I paid 20 bucks for a set from a junkyard.....
Old Dec 8, 2013 | 07:07 AM
Thanks, I've found one new oem auto hub assembly left in the country for a cool $535. So even though I hate to alter this one I'm trying to get past that.
Old Dec 8, 2013 | 07:33 AM
JasonYota's Avatar
That's crazy. I'd swap to manual hubs
Old Dec 8, 2013 | 10:01 AM
RustBucket's Avatar
Manual is the way to go. Check the classifieds section, I have a nice cleaned-up pair for sale. I'm also in GA.
Old Dec 8, 2013 | 12:16 PM
Where do i get those?
Old Dec 8, 2013 | 01:49 PM
wyoming9's Avatar
Red face
You can get new from your dealer or see if where ever you get your hubs from has them
You want every thing that comes off with the manual hubs
Good to have the Correct size socket as well 52MM sure beats hammer and chisel
Old Dec 8, 2013 | 02:09 PM
millball's Avatar
Aren't the spindle nuts 54mm??
54mm= 2 and 1/8 inch.
Had to break out the 1 inch drive stuff to find a socket that big when I packed my bearings a few weeks ago.
Old Dec 8, 2013 | 02:16 PM
wyoming9's Avatar
Red face
Been one of those days,
Now I can`t even find the socket .
Old Dec 8, 2013 | 02:17 PM
JasonYota's Avatar
Originally Posted by millball
Aren't the spindle nuts 54mm?? 54mm= 2 and 1/8 inch. Had to break out the 1 inch drive stuff to find a socket that big when I packed my bearings a few weeks ago.
Yea they're 54mm. You shouldn't need that socket to swap to manual hubs though
Old Dec 8, 2013 | 02:21 PM
millball's Avatar
True, but it would be a shame not to repack the bearings if its been awhile, when you're into the front that deep.
Old Dec 8, 2013 | 02:26 PM
JasonYota's Avatar
Good point
Old Dec 8, 2013 | 02:55 PM
Ok. When you said extra it made me think it was something i'd need to add. And thanks on the socket size. That'll save an extra trip.
Old Dec 8, 2013 | 03:02 PM
JohnnyCanuck's Avatar
Not including rebuilding/painting the hubs, it took me under 2 hours to take out add hubs and install aisin hubs.
Old Dec 8, 2013 | 03:09 PM
Cyberman's Avatar
http://www.4x4wire.com/toyota/tech/autohub/
Old Dec 9, 2013 | 12:43 AM
wyoming9's Avatar
Red face
The auto Hubs only have one nut.
to swap to the manual hubs you should have the thrust washer the adjusting nut the lock ring with the tabs you bend over and the lock nut the one that holds the whole thing on.
