drivetrain noise...
Old Dec 23, 2007 | 06:11 PM
Malczuk4runner's Avatar
drivetrain noise...
in every gear, if im maintaining speed, not accelerating nor decelerating, something in my drive train makes a wining noise. i leaned into the back of my truck and it sounded like it was coming from the rear, so i checked my diff fluid, it was 1/4 L low, but i topped it up and it still makes noise.the truck was stored for about 3 years before i bought it, but the gears were redone a month before it started to sit. the diff fluid is topped up, its not the u-joints, im out of idea's. i hope my ring and pinion are not set wrong. any other idea's? i don't wanna rip out my drive shaft and gear assembly to check anything, but if someone is certain they know the problem it'll have to be done...
Old Dec 23, 2007 | 06:55 PM
thook's Avatar
Hmmm....if you're sure it's in the drivetrain and it's not a u-joint.....sounds like the diff is probably set wrong. A whining noise is typical symptom of that, as you seem to know. I wouldn't know how to check for that myself, though. Maybe Zuk will chime in.
Old Dec 23, 2007 | 06:56 PM
mr toytech's Avatar
might be a pinion bearing. these trucks are known for that.
Old Dec 23, 2007 | 07:02 PM
thook's Avatar
They are? Even with a replacement having been done recently as his?
Old Dec 23, 2007 | 07:03 PM
devldogs55's Avatar
Had the exact same systems. Fixed it by putting in a e-locker 3rd... but mechanic said my old diff had bad pinion bearing
Old Dec 23, 2007 | 07:06 PM
mr toytech's Avatar
may not of set the preload right or didnt replace the bearing and or the crush sleave.
Old Dec 23, 2007 | 07:09 PM
4runnerguy's Avatar
i could be the baring thats my guess try and do this take the drive shaft of from the rear diff then pic it up with a jack and spin the pinion and see if there is any play
Old Dec 23, 2007 | 07:10 PM
thook's Avatar
Oh, okay..... I see what you mean. Gosh, why would someone not replace those? Seems kinda silly to me. Preload not being right, I can understand.
Old Dec 23, 2007 | 07:15 PM
mr toytech's Avatar
stupid people do stupid things!!!!
Old Dec 23, 2007 | 07:26 PM
thook's Avatar
And thank God for that. I should be a millionare by the end of next year with my new line of hats (the conicle type) on the market. Christmas is already looking very profitable....
Old Dec 23, 2007 | 07:30 PM
mr toytech's Avatar
true that
Old Dec 24, 2007 | 07:47 AM
its not the u-joints, the driveshaft has no play in it at all.. i guess im gunna have to live with it for a bit... if the pinion is not set right, over time can it do alot of damage? or is it just going to be annoying
Old Dec 24, 2007 | 09:39 AM
mr toytech's Avatar
it could send metal thruogh out your whole third member
Old Dec 24, 2007 | 04:17 PM
84sr5yoty's Avatar
It could be axle bearings.
I recently replaced all 3 u-joints and the center bearing after hearing a slight moaning sound that started at 52MPH. Problem wasn't fix so i bought genuine Toyota axle bearings and seals and had them pressed in. Problem solved.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
TheBFA
Feb 15, 2020 06:55 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
sonorn67
Sep 19, 2015 05:39 PM
87blyota
Sep 14, 2015 08:38 PM
