Banjo bolts
Old Dec 16, 2007 | 06:01 PM
js9924's Avatar
Banjo bolts
So I blew a head gasket on my 3vze and decided to rebuild it so im putting it back together and I cant get the banjo bolts on the fuel rails to line up right. Also while im here how do I prime the fuel system and the oil pump. thanks for your help and i would have pics but we are unpacking and my girlfriend lost the usb cable for the camera. The pics are coming soon
Old Dec 16, 2007 | 08:38 PM
DeathCougar's Avatar
for the fuel rails, loosen everything up without removing anything. Once you get all the bolts started, then snug everything down.
No reason to price the fuel system, and the only way to prime the oil pump is to turn the engine over since its crank driven. Just disconnect the coil wire, and turn it over until it gets oil pressure.
Old Dec 17, 2007 | 02:20 AM
TNRabbit's Avatar
Put something thick, like STP oil treatment, in the oil pump before you install it. that'll keep it from sucking air until it gets oil flowing....
Old Dec 17, 2007 | 05:28 AM
js9924's Avatar
I just cant get the holes in the banjos to line up with the ones in the fuel line it will be too tight or too loose.
some drunk guy
Aug 3, 2021 06:09 PM
Zach_trun
Jan 22, 2020 04:42 PM
mistershmi
Jan 5, 2016 11:07 AM
JUICE222
Oct 13, 2015 08:50 AM
Gone Fission
Sep 14, 2015 08:33 PM
