Best way to lube windows?
Old 12-18-2007, 12:26 PM
Tdubbs05's Avatar
The rear cargo window as well as the rear passenger door windows on my 4runner are moving pretty slowly and are definitely stuggling to go up and down and i wanted to see what other people have done to fix this issue. I'm trying to think of something that will lube them but not leave streaks all over the windows. Any thoughts?
Old 12-18-2007, 01:04 PM
nick_8787's Avatar
I shoot some kind of lubricant or rubber treatment on the bottom which has seemed to help, I have the same issue you do, both my rears are pretty slow. I spray the stuff on cycle the windows up and down quite a few times then wipe off the window.
Old 12-18-2007, 01:30 PM
az4x4runner's Avatar
I'd use white lithium grease.
Old 12-18-2007, 01:31 PM
Matt16's Avatar
I am also interested. Does removing the service panel and cleaning the inside help at all?
Old 12-18-2007, 02:13 PM
89pickupsr5's Avatar
what about the rear sliding window
Old 12-18-2007, 02:25 PM
gonzo's Avatar
I spray the rubber tracks with silicone spray. Start at the top and let it run down the track. Run the window up and down a couple of times then spray some more.
Also another thing I do in the winter is I spray some silicon on a rag and wipe the doorseals good and wet. It helps keep the doors from freezing to the rubbers. Another good winter idea is to spray "lock ease' in your door locks a couple of times a year. Helps keep them lubed and from freezing.
Hope this helps
Old 12-18-2007, 03:22 PM
Tdubbs05's Avatar
Hope this helps
darn good ideas right there. thx man
Old 12-18-2007, 05:03 PM
idanity's Avatar
this happened to my crank type window.
it was a pita. and ripped from being too tight.
after i replaced it w/dealer oem new weather stripping, it glides as if its in silk.
so, i think the rubber just warps and hardens into a crumby seal. buying a new one will definately cure the trauma.
RDubya
02-10-2017 04:46 PM
PNW94Runner
09-29-2015 02:55 PM
tazman1972
11
09-28-2015 10:32 PM
punks_is_4x4
09-19-2015 05:52 AM
mat
09-17-2015 11:18 PM
Quick Reply: Best way to lube windows?
