Crank pulley
Old Dec 16, 2007 | 10:00 AM
Kaydon's Avatar
Crank pulley
Any advice to get this sumbitch off? The bolt is torqued down hard, used an impact wrench to no avail, I took out 2 of the small bolts and stuck some longer bolts in there and put a pry bar and tried to use a pull bar while holding the pry bar to keep from turning the pulley.. Banged on the pull bar with a hammer... Is it reverse threaded? I didn't try that..
Also there's no real space to get behind it with the gear puller so any ideas to do it without damaging the pulley?
Old Dec 16, 2007 | 10:14 AM
langzaiguy's Avatar
A couple days ago I actually loosened it by accident. I was about to adjust my valves and I was putting the crank on TDC when I "bumped" the crank by turning the ignition with the line to the coil removed. I accidentally had a breaker bar on the crank. By keeping the breaker bar stationary, you'll loosen it up.
Old Dec 16, 2007 | 10:30 AM
86tuning's Avatar
breaker bar on the left upper framerail plus bumping the starter for 1/2 sec usually gets that thing loose.
Old Dec 16, 2007 | 10:54 AM
Kaydon's Avatar
With the head and everything off? lol
Old Dec 16, 2007 | 10:59 AM
DeathCougar's Avatar
should have pulled the bolt first dummy lol.
If the head is off, that even better. You can still bumper the starter as long as its hooked up. Just make sure there is nothing rotating that can catch, or at least make sure that chain is out of the way.
Old Dec 16, 2007 | 11:00 AM
EWAYota's Avatar
We just heated it up with a small torch. That was after we broke two sockets and a ratchet wrench.
Old Dec 16, 2007 | 11:10 AM
Kaydon's Avatar
Smart-ass yank!
I would've had I known what I was doing when I ventured into this! Maybe I should buy that FSM lol.
It's not hooked up as of now..
thinkin about it
http://img86.imageshack.us/img86/8228/yota122rg6.jpg do all these 4 have to come out?
Old Dec 16, 2007 | 11:31 AM
Originally Posted by Kaydon
No, the only thing those 4 bolts do is hold the PS pulley on. They can and should stay bolted in.
Old Dec 16, 2007 | 11:34 AM
Kaydon's Avatar
That's what I figured but I wasn't sure.. Is it reverse threaded? righty = loosey?
Old Dec 16, 2007 | 11:36 AM
Nope, regular thread. Righty tighty, left loosy!
but its on there with a lot of torque lol.
Old Dec 16, 2007 | 11:40 AM
Kaydon's Avatar
Okay, cool.. Thanks again, ahah.. Yotatech is my FSM, damnit.
I'll figure something out.
Old Dec 16, 2007 | 11:42 AM
Victor's Avatar
The starter trick works with most cars.
Old Dec 16, 2007 | 11:44 AM
im going to start charging you for my advice lol
Old Dec 16, 2007 | 11:47 AM
Kaydon's Avatar
*luke skywalker voice* Noooooooo!!!!
Old Dec 16, 2007 | 11:55 AM
Victor's Avatar
You can use a pipe extension on the breaker bar and put it against the ground. Works great. Putting it back on is on you - impact and Loctite works.
Old Dec 16, 2007 | 04:34 PM
billmaness's Avatar
Do you have a real inpact or a Hasbro/Mattell from wallyworld?
-Get a bigger wrench! It's just labor bound.
Old Dec 16, 2007 | 09:20 PM
slater442w30's Avatar
torch is your friend, about 90 percent of cars that come into my shop for timing chain/belt jobs have balancer bolts that wont come off even with the 1 inch impact gun with two guys holding that monster, then I watch them mess with it for about 20-30 minutes, stroll over with the torch, heat the bolt, remove it with my blue point 1/2 inch impact gun and watch them cry, its great. Just heat the head of the bolt up red hot, let it cool for just long enough to not be glowing and hit it with the impact gun. I have broken a lot of snap on impact sockets on hondas before the torch method.
Old Dec 17, 2007 | 11:48 AM
just a 22re's Avatar
just dont brake the bolt heating it up though thats a bad thing plus its on there with about 180 foot pounds and thats 20 years ago so its up to about i dont know 300 or more even foot pounds but yeah who cares braker bar right frame rail on top and hit that starter or hold it dont mater just dont hurt your self or your wife (your rig)
Old Dec 17, 2007 | 06:12 PM
mheart624's Avatar
chain wrench around the balancer and 1/2 breaker bar it- never had it fail....of course i am in AZ..no rust. but its worked for 100 plus yota t-belt job so far.
