Rough idle
Old Nov 17, 2017 | 05:38 AM
Bhhubbard21's Avatar
Rough idle
I am having idle issues as well. I changed the temp sensor and the tps which I adjusted using an ohm meter. It was giving codes for both of those items. After clearing the codes no new codes were found. It still has a great start up but after a few seconds it goes into a rough idle and dies. Anyone know what this might be??
Old Nov 17, 2017 | 08:20 PM
maco35's Avatar
Check for vacuum leaks and adjust your valves, and also post what engine you are having problems with.
Old Nov 17, 2017 | 10:26 PM
Co_94_PU's Avatar
Can you hold the throttle slightly open and keep it running and smooth? Perhaps your idle speed needs adjusting.
Old Nov 18, 2017 | 03:59 AM
No change
It runs great for the first few seconds and then it goes into the rough idle and dies. I can feather the accelerator and keep it running but it is really rough and never smooths out.valves are good and vacuum has Been checked. 88 22re in 88 pickup
Irish25
9
Jul 6, 2018 02:24 PM
captainslow
Oct 14, 2017 02:18 PM
no_3of4
May 10, 2017 02:05 AM
Heironymous Josch
May 6, 2017 01:36 PM
DrCreosote
Apr 20, 2017 05:16 PM
