clutch problem
Old Dec 6, 2017 | 05:17 PM
robrat's Avatar
clutch problem
Yes! I can shift it into gear with the engine off, and the clutch in, but I have to force it. To get it to move (home) I put it in gear, started it, and it immediately lurched forward with the clutch still in. When I pushed the clutch in with the engine running I was unable to disengage the gear (first). I turned it off, crammed it into gear, started it, lurched forward with the clutch out, and cruised on home.
Old Dec 6, 2017 | 05:42 PM
akwheeler's Avatar
Don't start a new thread every time you respond to a question, please continue with the previous post and tell us what year make and model that will keep all of your questions and answers in one place. if you have a hydraulic clutch you need to see if it's leaking, fix that and bleed it. It could also be a problem with the throwout bearing or the clutch itself, but one thing at a time, is the clutch master cylinder full?
swampedout
Jul 16, 2018 02:25 AM
irv
Apr 8, 2017 09:32 PM
1994toyota
Apr 8, 2017 07:32 AM
habanero
Nov 10, 2009 12:53 AM
YoterTillDeath
Jul 4, 2002 03:13 PM
