22re injector pulse while engine off
Old Nov 21, 2017 | 10:34 AM
highridinyota's Avatar
93 toyota pickup 22re cali emissions.
truck will fire up and run at a high idle for lets say a minute or so . After that short period of time it ˟˟˟˟s down like you flipped a switch. With the key in the on position you can hear the injectors clicking and the occasional electric arc in the distributor. All while the engine if off and just the key in on.
ive replaced the afm and the coolant temp sensor and am trying to figure out how to position the rag in the fuel tank for optimum fuel ignition when i burn it down . Any ideas fellas before i do something ill regret to this old truck . Its life is yalls hands. .....
Old Nov 21, 2017 | 03:56 PM
wallytoo's Avatar
i vote for burn it.
Old Nov 21, 2017 | 04:56 PM
Co_94_PU's Avatar
Distributer, igniter, ECU or the wiring in between..
Old Nov 21, 2017 | 08:28 PM
RAD4Runner's Avatar
Originally Posted by highridinyota
... With the key in the on position you can hear the injectors clicking and the occasional electric arc in the distributor. ...
Key in Accessories? or Ignition On?
If Ignition on and injectors are clicking:
1) The wiring on the ground side of the injectors (In red below...) could be shorting to ground, OR
2) The ECU is bad and is connecting the ground side to ground when when it's not supposed to
My guess and hope is just (1). Inspect your wiring.
To eliminate doubt on (2) Disconnect pins #20 (Wht) and #10 (Wht-Red) from ECU connector and see if the clicking persists when IG is on.
Old Nov 22, 2017 | 06:04 AM
Thanks for the input guys . I opened the ecu and found whats pictured below . Appears a capacitor has burn up on the board so its gonna need ecu work regardless
Old Nov 22, 2017 | 06:15 AM
92ehatch's Avatar
That looks like some traces burned up as well. I would check for any shorts in the wiring or any fuses that are bypassed, or larger than they are supposed to be before sticking another one in its place.
Old Nov 22, 2017 | 07:44 AM
Melrose 4r's Avatar
5 Year Member
look at all the beautiful analog electronic components! So easy to fix...if you can get the parts and traces aren't burnt like 92e said above.
Old Nov 22, 2017 | 09:05 AM
RAD4Runner's Avatar
Most welcome.
...Appears a capacitor has burn up on the board so its gonna need ecu work regardless
AHA!
+1 on inspecting traces and shorts and bypasses.
highridinyota,
Mind noting down part number of your ECU? Or sharing picture of label? It would be good for reference.
Originally Posted by Melrose 4r
look at all the beautiful analog electronic components! So easy to fix....
YUP! The beauty of simple engine.
Old Nov 22, 2017 | 09:28 AM
Label is gone off ecm. Toyota run the vin and said it should have a 89661-35850 in it . Local computer shop had a capacitor . Gonna clean it up a bit and give it a try
Old Nov 22, 2017 | 10:56 AM
Update- truck fired up runs and drives fine . Hopefully problem is solved and not just takinging the week off
