Combo meter
Old Nov 4, 2017 | 09:42 PM
tacobo670's Avatar
Combo meter
1994 Toyota pickup with 4Runner SR5 cluster swap. Been running this setup for 3+years.
Now, Speedo, Tach, Volt, Oil, Temp are all INOP.
I have yet to check wires, fuses, ground. Just wanted to know if anyone else had this prob before i start ripping things apart.
The cluster just went out today. I noticed this when i had started my truck, the Volt gauge needle dropped. I physically checked charging voltage at battery -was good. Went back inside, noticed all other gauges INOP.
Also, when key is in IGN ON position, the door-open buzzer will sound. Truck never did this before. So i suspect either bad ground/wiring issue or the cluster shorted somewhere.
Input please
Old Nov 5, 2017 | 01:04 AM
millball's Avatar
Failing ign switch??
Old Nov 5, 2017 | 01:05 AM
wyoming9's Avatar
Red face
Sounds like the gauge fuse opened
This is common from the harness from the fuel sending unit rubbing till it shorts.
Though it very well might be any place.
Old Nov 5, 2017 | 10:17 AM
RAD4Runner's Avatar
Always specify model-year-ENGINE-TRANSMISSION-trim when asking for help. One engine may have different schematic from another.
RAD4Runner
Jan 25, 2023 04:21 PM
spitfire4
Mar 3, 2018 11:07 AM
littlevulture
Feb 18, 2018 10:51 AM
AmirK
Oct 25, 2017 05:23 AM
RAD4Runner
Aug 17, 2017 02:35 PM
