Combo meter
Combo meter
1994 Toyota pickup with 4Runner SR5 cluster swap. Been running this setup for 3+years.
Now, Speedo, Tach, Volt, Oil, Temp are all INOP.
I have yet to check wires, fuses, ground. Just wanted to know if anyone else had this prob before i start ripping things apart.
The cluster just went out today. I noticed this when i had started my truck, the Volt gauge needle dropped. I physically checked charging voltage at battery -was good. Went back inside, noticed all other gauges INOP.
Also, when key is in IGN ON position, the door-open buzzer will sound. Truck never did this before. So i suspect either bad ground/wiring issue or the cluster shorted somewhere.
Input please
Input please
littlevulture
Feb 18, 2018 10:51 AM
AmirK
Oct 25, 2017 05:23 AM
