90 2nd Gen 4Runner Keeps Breaking Mufflers
Old Sep 22, 2015 | 05:03 PM
JookUpVandetti's Avatar
Hey guys thinking of pulling the trigger on a 90 4runner with a 3.slo with a SAS running 35s lockered and geared
Seems like a pretty good deal it's from a friend. Says it has an exhaust issue as it keeps breaking mufflers, as in the factory weld in the mufflers, ummm any ideas?
Old Sep 22, 2015 | 05:05 PM
Cracks at the moment face of the can. the flange.
I thought motor mount but they are good.
Old Sep 23, 2015 | 12:50 PM
wyoming9's Avatar
Red face
If you beat the snot out of most anything you can manage to break anything.
I think this is a driving style problem all those hard landings trying to be the General Lee
Then if he is buying junk mufflers replacing them every two weeks.
If the muffler is breaking what else is braking .
Give them the benefit of the doubt Maybe they have the exhaust system mounted to ridged
Old Sep 24, 2015 | 01:38 AM
Terrys87's Avatar
Probably the way he is driving or it is not mounted/supported correctly. An exhaust shop should be able to add support needed to keep it from cracking.
Old Sep 24, 2015 | 01:45 AM
dropzone's Avatar
Fossilized
there should be a rubber isolator or donut at each exhaust hanger that goes between the mount and the exhaust tube/muffler.
exhaust hanger
Old Sep 24, 2015 | 03:07 AM
AKHeathen's Avatar
It could be a fueling issue. hard to belive timing and no other symptoms. pull the plugs and read them. A dead cylinder would do it, provided the cat is gutted or removed. I've seen it in different vehicles where it will ignite unburnt fuel in the muffler and blow the end off. even bought a first Gen z24 that turned out to have a seized distributor advance. repaired the muffler since it looked good otherwise and less than a mile it blew out the muffler and I almost blew out my pants next to a cop, lol. if the cat is good, it would cook cherry red from the unburnt fuel. I cannot think of another reason a muffler would do that...... well, actually if the bump stops are gone you can bottom out on the exhaust pipe off roading.
Old Sep 24, 2015 | 02:50 PM
wyoming9's Avatar
Red face
Quite a difference between a cracked weld and the muffler being blown up from un burned fuel
Could be cheap mufflers with poor welds
Old Sep 24, 2015 | 02:58 PM
Thanks guys for the comments. It could possibly be just a cheap muffler as that is what he said was on it but I'll definitely check the other ideas out as well.
Jun 1, 2021 01:51 PM
skoti89
Jul 6, 2015 07:45 PM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
