Missing bolts on valve cover?
Old Apr 30, 2016 | 02:41 PM
mattyboi's Avatar
90' 22re manual with 347,000km.
Just got this truck recently and I noticed that 4 bolts are missing on the valve cover. How likely is it that they just rattled out? Should I go ahead and put in a new valve cover gasket? So far the truck runs fine. Only codes I'm getting are 25 and 26 which so far I've isolated as a faulty O2 sensor. Unfortunately I sheared the stud off but I managed to get that section of exhaust out so hopefully tapping new holes will go smoothly.
Also how on earth do I take out the PCV valve?? I was pulling so hard I nearly lifted the front end off the ground
Here are some pics for reference:
Missing bolts on either side of the oil fill cap. Missing two others. Could it maybe be for an engine cover that has gone MIA?
Closeup of gasket
Old Apr 30, 2016 | 03:38 PM
old87yota's Avatar
Not all of the holes need bolts. The only thing that holds the valve cover on is the four acorn nuts that have the thick rubber washer under them (Its the nuts just behind the holes you mentioned).
The bolt holes that are empty are for different configurations and different models. Some will be used to bolt down various brackets and others will not.
As for the PCV valve, I ended up taking out the grommet with it when I put a new valve cover gasket on my truck. The grommet is probably rock hard making the PCV valve hard to remove. Try to remove the grommet with the valve and replace that too.
Old Apr 30, 2016 | 04:51 PM
mattyboi's Avatar
Well that's a relief! Hopefully the PCV valve will come out next time.
Old Apr 30, 2016 | 11:31 PM
wyoming9's Avatar
Red face
Instead of trying to fix that heat cycled O2 Sensor Bung just get it new one so much faster.
After trying the first time and breaking a tap and getting it stuck I just cut the old ones off and weld a new one on .
In the great Northeast fighting with broken rusted hardware is a fact of life.
Old May 1, 2016 | 08:29 AM
mattyboi's Avatar
Already have a new sensor waiting to go in. I'll try to tap it first and see what happens. If it doesn't work, I don't have a welder but I'll see if I can clamp in on tight with something instead lol
mattyboi
Jun 4, 2016 11:46 PM
tomboarderns
May 15, 2016 10:13 AM
lexx05
Apr 29, 2016 03:32 PM
Murfy101
Apr 25, 2016 08:16 AM
jayd513
Apr 16, 2016 11:36 PM
