Park brake cables
Old Apr 19, 2016 | 04:53 PM
'86 Xtra cab 4wd's Avatar
Park brake cables
My 86 toyota pickup xtra cab was missing the rear brake cables when I bought it so now I'm having to search for them and can't seem to find any luck. Just seeing if any one has a link or knows where I can find them so I can use the park brake instead of having to leave it in gear and shut it off every time I have to get out even for just a minute..
Old Apr 19, 2016 | 07:12 PM
scope103's Avatar
You searched for them? Where?
http://parts.lakelandtoyota.com/show...rimLevel=18292
About $70 each. Use your VIN to be sure you get the right part; "xtra cab" isn't enough.
Old Apr 19, 2016 | 07:16 PM
I just Google and and looked ebay but I'm never suse about there cause I've got things from there that were really cheap or wrong. But thanks I'll try my Vin and see what I get. I went to that page before but I've never owned a 4runner so I didn't know if it would be the same part for it as for my pickup so I kept looking
Old Apr 19, 2016 | 09:52 PM
This is part of the cable the goes to the back brakes from this bracket. As you can see it was cut for some reason so i need to get them replaced and i should be good.
Old May 1, 2016 | 08:11 PM
Found a front cable on amazon and turned out to be too short.. it was for a standard cab. It did not state or give a choice of whether it was for a extended cab or regular.. so now I got to send it back. My front brake cable also has the end on it with the hole for the pin to go through. Can find the cables with the same ends on it all day long but not the one with the hole for the pin..
SilentBounty
Mar 22, 2016 10:29 AM
SueLu
Feb 24, 2016 08:23 PM
alva22re
Feb 20, 2016 04:21 PM
goofybud16
Feb 6, 2016 01:29 PM
