lower radiator hose
Old Mar 30, 2016 | 05:27 AM
skeeter0288's Avatar
lower radiator hose
just pulled truck apart to replace timing chain , and am curios to see if any one has ever reconfigured the lower radiator hose to do away with the wrap around metal pipe and have just one hose off the block to lower radiator connection .
Old Mar 30, 2016 | 03:43 PM
wyoming9's Avatar
Red face
Why ??
The third generation Celica`s with the 22Re used one long hose
If I recall it was quite expensive
Old Mar 30, 2016 | 05:13 PM
after I pulled it aprt I found the 90 degree elbow from the block outlet to the water pipe has been leaking, and I did not even know it was there . apparently , neither did my uncle, who bought it new . it has never been changed. I see it like this-the more connections and clamps you have , the bigger possibility of a failure .that is why I was considering re-routing the hose with one hose and doing away with the metal pipe. just a thought , getting the engine back together with 261c cam and new header will take first priority.
Old Apr 1, 2016 | 02:01 PM
wyoming9's Avatar
Red face
Well what ever you do figure to do this make 2 .
Custom hoses will fail at the worst possible place on a Sunday
Up&Down
10
Apr 5, 2016 09:36 AM
Joshua White
Mar 19, 2016 03:17 PM
Prophet
Mar 16, 2016 05:02 PM
shudson248
Mar 7, 2016 06:18 PM
Nineonerunner
Mar 1, 2016 07:07 AM
