EGR temp sensor
Old Apr 20, 2016 | 03:04 PM
an1176's Avatar
EGR temp sensor
Quick question, I have a 94 22re 4x4. I did an egr delete and now I keep getting a code 71 egr temp code. I expected it. Anyways I've read and researched and found that if you get a 10k ohm resister you can fool the code. I've even seen some pictures. In the pics it looks like the resister is attached to the temp gauge connector itself not the female connector coming from the ecu. Since the temp probe is no longer connected to the ecu how in the world does this fool the ecu? Do I need to plug the two connectors back together with the resistor in the middle? Thanks
Old Apr 20, 2016 | 08:31 PM
MudHippy's Avatar
Do what makes the most sense to you. You've got the right idea. You didn't really even need to ask. It doesn't hurt to though. I don't think any less of you for it.
Hint: It goes in the plug. But don't plug both into the sensor.
Old Apr 22, 2016 | 04:25 PM
BajaRunner's Avatar
The female plug. Just make a U-shape with the resistor and put one end in one terminal, and the other end in the other terminal.
Old Apr 22, 2016 | 04:29 PM
an1176's Avatar
Thanks bajarunner. I tried that with the resistor and still got a code. I read some where to do same thing with a paperclip. I did that yesterday and so far so good.
brianroland97
Jul 8, 2020 09:06 AM
admiralnahohkta
Mar 1, 2020 01:44 PM
atoliver
Mar 3, 2016 06:57 PM
kanyonkritter
Feb 27, 2016 11:08 AM
Tommy T.
Feb 20, 2016 07:08 AM
