fuel pressure regulator leaking
Old Apr 24, 2016 | 01:43 PM
ianD's Avatar
I have a bad fuel leak from the pressure regulator, like a steady stream. It seems to be leaking from the sealing area with the fuel rail. I had taken it off during my engine rebuild when I was cleaning everything and it never leaked before. I took it off and made sure the sealing surface was good and clean but when I put it back on it leaked just as bad. Anybody had trouble getting one of these to seal?
Old Apr 24, 2016 | 02:42 PM
wyoming9's Avatar
Red face
Been quite some time but is there not a crush washer that goes on there ??
Old Apr 24, 2016 | 04:57 PM
ianD's Avatar
There's a thin steel washer, i figured it would have been a copper one like most other fuel fittings. Seems like i'd have to cut it to get it off though, like the inner diameter of the washer is smaller than the diameter of the threads. Is there a possibility that the regulator itself is leaking and it just looks like it's coming from the seal?
Old Apr 24, 2016 | 07:13 PM
muddpigg's Avatar
X2 on crush washer. Good for one maybe two uses. Should be copper not steel.
Old Apr 24, 2016 | 07:24 PM
ianD's Avatar
I just did a google image search for "1991 toyota pickup fuel pressure regulator" and the pictures show a steel washer and an o-ring. Does this sound right? I can't remember if mine had an o-ring or not when I took it off.
Old Apr 24, 2016 | 07:25 PM
muddpigg's Avatar
Doesn't sound right to me.
Old Apr 24, 2016 | 11:46 PM
wyoming9's Avatar
Red face
At this point it can`t hurt to try just make sure the o ring is safe to use with whatever chemicals are added to gas these days.
You don`t want it dissolved with the first contact.
Then the regulator could be leaking itself
Old Apr 25, 2016 | 03:57 AM
wallytoo's Avatar
the FPR uses a rubber o-ring and steel washer. the washer would be difficult to remove from the FPR.
if it leaks, the o-ring might have a crack or tear in it. buy another o-ring or a new FPR.
wally
Old Apr 25, 2016 | 07:00 AM
scope103's Avatar
wallytoo is correct; it is an o-ring, not a crush washer.
Old Apr 26, 2016 | 11:15 AM
ianD's Avatar
Threw an o-ring on there and it sealed up, thanks. Finally got my camshaft break in done on the new engine, hoping to hit the road after some tuning
some drunk guy
Apr 7, 2016 08:43 PM
ianD
Apr 6, 2016 12:12 PM
AlphaLady777
Mar 31, 2016 08:32 AM
westcoastkevin
Mar 29, 2016 10:58 AM
