U bolt brackets
Old Apr 24, 2016 | 07:24 AM
gotduhka's Avatar
U bolt brackets
On my 1994 pickup there are a set of sandwiched brackets that go around the leaf springs where the ubolts are. Does anyone know if these are necessary or if I can remove them when adding ome springs? The have thin rubber inserts in them.
Old Apr 24, 2016 | 08:09 AM
MudHippy's Avatar
You can. But you won't be able to use the bumpstops. The bumpstops can't be seperated from the upper bracket. They're one piece. The term necessary only applies if you consider bumpstops necessary. Most you will tell you yes, they're necessary. And they're certainly necessary to prevent damage if you bottom out the suspension.
You could probably cut them off of the bumpstops. And just reuse the bumpstops. But I'm wondering why you want to get rid of the brackets in the first place. Is there a fitment issue?
Old Apr 24, 2016 | 08:24 AM
gotduhka's Avatar
The bumpstops rest on top of these brackets.
Old Apr 24, 2016 | 08:26 AM
gotduhka's Avatar
Old Apr 24, 2016 | 08:34 AM
gotduhka's Avatar
Might remove them after fixing pinion angle. It will allow my e brake to clear
Old Apr 24, 2016 | 09:49 AM
MudHippy's Avatar
Holy triple post Batman!
Unless they've been previously removed/cut off of the brackets, your terminology is flawed. The word rest implies they are seperate from the brackets. I'm telling you with authority that is not the case.
Thanks for the pic. I wouldn't be able to understand what you meant by removing what to clear the e brake cable without it. I see you mean the springs. And not the brackets or the bumpstops. Unless that's not what you mean. In which case good luck with that. Won't do a lick of good.
Old Apr 24, 2016 | 10:44 AM
gotduhka's Avatar
I have removed mu springs for add a leafs, omes, and new u bolts 4 times, I am telling you that the lower bump stops absolutely are not attatched to the bracked just below the top of the u bolts. I will loose 1/4" of lift by removing the brackets, which as you can see, no longer even meet each other in the middle.
Old Apr 24, 2016 | 11:31 AM
gotduhka's Avatar
Its the lower braket that I would remove anyways.
Old Apr 24, 2016 | 11:36 AM
MudHippy's Avatar
Yeah...well I'm about to prove you wrong. If you think that's how they were originally. Because it's not. The bumpstop, bracket, and rubber pad are all one piece. Bumpstop/bracket/rubber pad = 1 unit. And they never did meet in the middle either. But that's besides the point. Will removing them solve the cable issue? Maybe. I'll give you that much.
BTW, are you aware there's supposed to be galvanized steel plates below those too?
Oh...you're lucky I'm in a good mood today. I'll be right back with some pics of my own.
Old Apr 24, 2016 | 11:44 AM
gotduhka's Avatar
The galvanized plates are still there as is the rubber. The stock springs did allow these plates to meet, you can still see where the tab folded over in the picture above. I bought this stock from original owner. The bump stop fits over a 1/2" tube keeping it in place. Check parts 14 and 15
Old Apr 24, 2016 | 01:21 PM
MudHippy's Avatar
Maybe in some cases they do meet. But on the stock springs I pulled at a junkyard, which were off a 92 IIRC, they didn't. Close, but not quite. But like I said, besides the point. Not going to bother proving that. And I realize they are seperate part numbers. But it makes no sense why. Because they aren't IRL. Or maybe just not in all cases evidently, or if you can prove yours were seperate from the factory. Which I'm prepared to believe if you'd show me. Not so much if you don't. Sorry.
You'd have to grind/cut that lip off to remove the bumpstop.
Old Apr 24, 2016 | 03:26 PM
gotduhka's Avatar
Strange, well in any case, maybe there is a hard poly I could just jb onto my spring where the cable runs. Im just going yo leave my pinion angle alone, with the camper on it gives no vibes. Minimal on accel when camper is off. Ill check my angles again in a week.
cars-guy
66
Jan 26, 2019 08:38 PM
iourius
27
Sep 23, 2016 11:54 AM
Havokgs
Mar 29, 2016 01:33 PM
Krog321
Mar 27, 2016 02:18 PM
mudharvest23
Mar 26, 2016 08:22 AM
