Fuel pump turns on when jumped.
Old Apr 25, 2016 | 06:28 AM
jzx81's Avatar
Hi there. I have a 1994 3VZE Manual 4runner.
I parked it for winter. This was maybe 4 months ago.
Now I come back and it won't start. When I jump the fuel pump at the dignostic plug it will run just fine.
What is going on? I've checked all my fuses, they seem fine.
Thanks ahead of time.
Old Apr 25, 2016 | 07:06 AM
scope103's Avatar
There is a problem in the VAF-COR circuit. Start with the VAF; with key-on, push the flap open with your finger. You should be able to hear the fuel pump run.
If the problem is that it won't start AT ALL, the problem could be on the ignition switch side. Pull the COR http://web.archive.org/web/201003261...96circuito.pdf and run the diagnostics. If it passes, check for STA on the relay socket when you turn the key to start (pulling the starter relay will keep the starter from turning over when you do this). Check for FC the same way.
Don't just drive around with the jumper in. If you get into an accident that breaks a fuel line, you want the pump to shut off immediately.
tomczaksdiesel
Apr 16, 2016 08:03 PM
jiggseob
Mar 23, 2016 04:20 AM
808-3VZE
Mar 16, 2016 05:09 PM
Questions
Mar 5, 2016 04:05 PM
Joey22r
Feb 27, 2016 04:24 PM
