94 pickup no click or no noise from fuel pump
Old 03-16-2016, 04:21 PM
808-3VZE's Avatar
My truck no crank or no sound from the fuel pump. Thought it was the computer so I tried another ecu same thing. Also checked the fuses and efi relay. Could it be the circuit opening relay? Anybody had this problem? Lmk any help is good.
Old 03-16-2016, 05:09 PM
scope103's Avatar
Originally Posted by 808-3VZE
... Thought it was the computer so I tried another ecu same thing. ...
That would have been my LAST guess.
.... Could it be the circuit opening relay? ...
Sure.
.... Anybody had this problem? ...
It seems there is a new discussion on this just about every day. I can't imagine how you could have missed this with the simplest of searches.
Start with easy stuff. Jumper FP to B+ and turn the key to "on." You should be able to hear the fuel pump. If not, almost certainly a bad pump (FP goes direct to the pump, but of course you could have an unlikely broken wire). If the pump is now running, your problem is in the VAF-COR circuit. (Don't go swapping out expensive parts, like the COR, at random.)
WpgWelder
34
05-26-2016 03:53 AM
87_toyota
03-06-2016 06:55 AM
89yota89
02-28-2016 01:11 PM
Joey22r
02-27-2016 04:24 PM
Calioutdoor
02-17-2016 08:56 AM
Quick Reply: 94 pickup no click or no noise from fuel pump
