i.a.t sensor location or wire color
Old Jan 10, 2013 | 10:17 PM
Manuel C. Cabico Jr.'s Avatar
Cool i.a.t sensor location or wire color
i have a 88 toyota pickup 4x4 and want to knw where is the I.A.T sensor wire and color ...thanks guys help me out plz
Old Jan 11, 2013 | 08:37 AM
Gamefreakgc's Avatar
Whoops, misunderstood the question.
This might help narrow it down though. I found it in the FSM and there's two connectors used that are measured based on temperature. My bet is those are the ones you'll want to try and follow.
http://personal.utulsa.edu/~nathan-b...33volumeai.pdf
The two wire connections are E2 and THA. I'm almost positive E2 is a diagnostic wire used for test mode... so the THA wire is the one to look at. It's located on the far right of the connector.
Your IAT is located inside of the Air Flow Meter.
P.S. I'm assuming you have a 22RE or 3VZ-E engine.
Old Jan 11, 2013 | 10:28 AM
MudHippy's Avatar
E2 is the sensor ground(common ground used by many sensor circuits).
THA is the Intake Air Temperature Sensor signal.
THA = THermistor(Temperature Sensor) Air(Intake Air).
It's the number 7 pin on the VAFM(either engine). The wire color is blue for 3VZ-E, yellow for 22R-E.
88 Wiring Diagram for reference.
Old Jan 11, 2013 | 11:03 AM
Thankx guys for ur help!! Found it niw i can install my new utp onto
sandyota
Feb 4, 2021 11:16 AM
coryc85
Sep 9, 2015 06:24 AM
Sep 4, 2015 09:27 AM
88yodabasket
Jul 13, 2015 01:32 PM
Johntom240
7
Jul 13, 2015 12:18 AM
