Input shaft bearing
Old Jan 10, 2013 | 01:57 AM
tysen86's Avatar
Input shaft bearing
My 91 sounds like it has a bearing going out in the tranny. I makes the sound in 1,2,3,5 and neutral. When I shift into 4th it's just as quiet and smooth as you could want. I have a couple questions; first, could an input shaft bearing be causing this and if so, why not 4th gear? Second, can a country boy like myself change and input shaft bearing or does it require some special pullers? The best way I know to explain the sound is, it sounds exactly like the throw out bearing did when it was shot and the clutch was let out. It's definitely a bearing.
While I got ya, if anyone knows where there is a tranny sitting in or around North Georgia, I could probly use it!!
Old Jan 10, 2013 | 02:26 AM
Terrys87's Avatar
My spare tranny that I was hoping was good does just the oppistite of yours. All gears are great except 4th gear. Almost sounds like exact same noise you are saying only mine is 4th gear only.
I dont know about changing input shaft, but I to am on the hunt for a tranny.
Old Jan 10, 2013 | 02:43 AM
hambob's Avatar
If it were the input shaft wouldn't make the noise in all gears? Just a thought. Have you checked the tranny oil?
Old Jan 10, 2013 | 03:31 AM
Pat8942's Avatar
It could be the input pilot bearings, they are the rollers inside the input shaft, it would make noise in every gear except direct (4thgear) because the input turns a different speed than the output in every gear except direct.
Old Jan 10, 2013 | 04:11 AM
tysen86's Avatar
Ok, so it could be the input pilot bearing, is this something I can change or do I need special tools?
Thanks for the input.
Old Jan 10, 2013 | 05:55 AM
ThatGuy1295's Avatar
You probably could change it. But I would just have the whole trany rebuilt at this point. Way worth it, compared to changing out one bearing and having the next one go out later. Tearing a transmission out 4 times in 4 years is a joke.
Old Jan 10, 2013 | 07:02 AM
tysen86's Avatar
Yea, I'm looking for another tranny so I can have this one rebuilt.
Old Jan 10, 2013 | 12:04 PM
tysen86's Avatar
Ok, my next question is, how do I find out if I have a G or a W tranny? And is one better than the other?
Old Jan 10, 2013 | 12:05 PM
tysen86's Avatar
Oh, there is not a data tag on the firewall.
Old Jan 10, 2013 | 02:11 PM
highonpottery's Avatar
mine had bad input shaft bearing. had noise in all gears but 4th, as well as in neutral (4th is direct gear) - sounded like marbles jangling around inside. decided it was best to just get it rebuilt. shop tech sent me a pic of my chewed up input shaft splines where 40-50% were broken off....yikes.
Old Jan 13, 2013 | 02:39 PM
Bigblock's Avatar
Could be the gears.4th really is not a gear so it cant make noise unless a bearing is bad.How much trans oil have you been adding?
Old Jan 13, 2013 | 02:45 PM
tysen86's Avatar
I added a quart yesterday. it don't ever leak. only leak on the truck is the rear main and its a small leak.
88sasturbotoy
Jan 30, 2026 01:57 PM
he's gone
7
Dec 3, 2019 07:08 AM
trailgoat
Aug 13, 2015 05:54 PM
JAmdor3
Aug 11, 2015 10:53 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
