what plug is this
Old Jan 13, 2013 | 07:40 PM
toyota32's Avatar
what plug is this
I found a 3 wire plug on the back side and top of the gastank near the shock on my 86 runner. one of the wires is broke. would this be why my fuel gauge isnt working. I have pix I can load tomorrow
Old Jan 13, 2013 | 08:08 PM
stock87's Avatar
Yep, that's for the gauge. 2 wires for gauge, 1 for low fuel light.
Old Jan 14, 2013 | 10:20 AM
toyota32's Avatar
can i buy just the plug some where cause its broke right at the plug. and thank you for the help.
Old Jan 14, 2013 | 10:33 AM
kelvinb's Avatar
upullit yard and clip it off one shouldnt cost more than 5 dollars i would hope
Old Jan 15, 2013 | 08:47 AM
toyota32's Avatar
does it have to be off a 1st gen runner
Old Jan 15, 2013 | 11:05 AM
Co_94_PU's Avatar
Hard to say you can try asking the parts counter person at the local autoparts store how many versions of pump they have for a general idea.
Don't forget to disconnect the battery first.
Cut the old one off and take it with you, make sure you cut it off high enough that if you decide to repair it you have enough wire sticking out to do so easily. When you cut the donor out cut it off three or four inches longer than you did the original, better too have to much then too little.
With a flash light or once you have it on the work bench, inspect it and you'll find the locking tab that holds the copper connector into the housing. Gently pry this out of the way and you can push the copper piece out the back or front of the housing. Now you can either pry open the clamps or twist and solder, depending how much wire is left.
Good self sealing water proof crimp connectors is the best way to go for reattaching. Since you're right next to the fuel..
That said you can probably get away with just twisting and taping.
Strip about two inches off each side.
(Slip on a piece of heat shrink tubing if you have a heat gun, plug in, or battery operated soldering iron.)
Now place them so you have overlap in the wire, with about one inch between the protective sheaths.
Now holding it in the middle twist/wrap the loose end around the wire slowly. (You want atleast four turns fully around the wire, more is ok less is not, don't overlap the wraps.)
Trim off the excess just short of the sheath.
Reverse your hold and repeat for the other side.
Now apply solder and shrink the tubing, with plug in iron or heat gun. (Not responsible if you blow your self up with a portable gas powered iron )
Or tape it up, take care that the sheathing is clean and dry and do not stretch the tape.
80Truck
Oct 12, 2025 07:25 PM
Blamalam
Mar 12, 2022 07:34 AM
old87yota
Oct 25, 2015 02:15 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
msane99
Jul 17, 2015 10:13 AM
