99' seats to 93' truck?
Measure your current and the new..
From memory the width is 16.5-17 inches and the depth is 14 inches. The front legs should be vertical and the rear horizontal.
The seat belt clips need to go under the rear inner seat mount, they don't fit atop the toyota brackets. Unless your replacing those with proper bucket ones, in which case they mount farther back and up the tunnel about an inch and a half.
All that said. Like it says else where you can fit almost anything with a drill and measuring tape.
