Am I testing the A/C compressor properley
Old Jan 20, 2013 | 09:45 AM
rbig18's Avatar
Hi,
Going though the testing of my A/C system. Attempted to test the compressor by disconnecting the single wire clip and sending 12 volts off the battery to the compressor. I got nothing. Just want to confirm I tested properly before confirming the compressor is toast.
Picture below- I sent 12 volts directly to the white clip you see hanging on the A/C line.
it is an 86 22re/5 speed
Attached Thumbnails Am I testing the A/C compressor properley-imag0656.jpg
Old Jan 20, 2013 | 09:53 AM
BigBluePile's Avatar
Ok, well that's not testing the compressor. That's testing to make sure the magnetic clutch is engaging to TURN the compressor. Which you can replace just that.
Old Jan 20, 2013 | 10:00 AM
rbig18's Avatar
Thank you for the reply. So based on this test it seems the clutch needs replacing at the least.
I am also not getting the A/C button to light up when depressed and have checked the fuse as well as hear the relay click. The system is empty of R12 and I suppose that could be why the I get no green light.
Old Jan 20, 2013 | 01:53 PM
rustypigeon's Avatar
You should hear the clutch energize when you put + voltage on the lead. You can also test the resistance of the stator coil. You should get 3.4-3.8 ohms (at 68 degrees F) between the lead and ground.
Old Jan 20, 2013 | 02:09 PM
vital22re's Avatar
totally a bro
The system uses hi/lo pressure sensor to keep the compressor from turning on if there is not enough gas or too much. With the engine running, if you put 12v to the compressor clutch, it should kick on and turn compressor.
Old Jan 20, 2013 | 02:21 PM
toyrunnerns's Avatar
with no refrigerant in the system the cluch will not engage. the light should come on anyways , but maybe it does 't . jumper the low pressure control to see if the cluch is good.
Old Jan 23, 2013 | 08:11 PM
rbig18's Avatar
Ok so I ended up ordering a reman compressor. My Plan is put it on, replace dryer and expansion valve. Replace all o-rings and swap in R-134a compatible oil and charge. Anyone see an issue with this plan? If it does engage at this point I would have to assume I am down to fuse/relay or switch under the dash.
Old Jan 26, 2013 | 01:17 AM
LITLRED's Avatar
Originally Posted by rbig18
Hi,
I've always taken my AC work to a shop. When the mechanic tested my compressor he had it out of the truck and showed me it was froze up.
The shaft would not turn.
mussy01
Dec 13, 2016 08:20 PM
JUICE222
Aug 21, 2015 05:16 PM
klavender1
Aug 15, 2015 01:51 PM
stock87yota
Jul 31, 2015 10:08 AM
bryan34w
Jul 6, 2015 05:53 PM
