Stiff gas pedal?
Old Jan 17, 2013 | 05:14 PM
NickMiller's Avatar
Stiff gas pedal?
After driving my 4Runner (88 3vz auto) for a while I've gotten tired of the EXTREMELY stiff gas pedal. I've been doing some searching and it seems like the best solution is to replace the throttle cable. The problem I see is that apparently it's called the "accelerator cable" and I'm not sure what part to buy?
Originally Posted by BajaRunner
Update: I finally got around to installing a new ACCELERATOR cable (Don't buy the throttle cable, thats for the transmission).
And it FIXED it... Yay! No more foot cramps with trying to push the gas to pass a HEEP!
I've been doing my research and ToyotaPartsZone shows a few different things that mention "accelerator cable" and the 1st one just seems like a bracket and the second one isn't even available...
Any Help is appreciated!
  1. 78184-35060 - BRACKET, ACCELERATOR CONTROL CABLE ($16.50)
  2. 78180-89146 - WIRE ASSY, ACCELERATOR (N/A Anymore)
Old Jan 17, 2013 | 05:19 PM
z31freakify's Avatar
just put wd-40 on the sucker and problem fixed no need to buy new one unless it's stretched already.
Old Jan 17, 2013 | 05:59 PM
NickMiller's Avatar
How do you know if it's stretched?
Old Jan 17, 2013 | 07:18 PM
TNRabbit's Avatar
Remove the end on the engine, hold it up in the air, and soak the hell out of it with WD-40 into the open end of the cable shaft.
Old Jan 17, 2013 | 07:19 PM
if you try adjusting it and you still have play it's stretched
if you have damage inside the insulator where the actual cable is you are going to have to replace it
but take into consideration they are old trucks and dust and moister eventualy go into every thing my suggestion is clean good with brake claner dry it up and put some of that wd or liquidwrench what ever to make that cable get lubricated and get it moving freely
What he said in short terms
JustToynAround
Aug 19, 2015 11:46 AM
auscal
Aug 19, 2015 11:00 AM
AppalachianOffRoader
Aug 12, 2015 12:55 PM
HollieJayyy
Aug 9, 2015 07:59 AM
D.B.T. 87 4x4
Jul 20, 2015 04:51 PM
