2 wire knock sensor VS one wire knock sensor 3vze
Old Jan 17, 2013 | 02:48 PM
big1000's Avatar
. I have a 94 engine that I'm putting into my 90 runner. the knock sensor on the new engine has two wires and the knock sensor on the 90 wiring harness which I'm using has one. which wires do I connect to get it to work?
Old Jan 17, 2013 | 03:53 PM
rattlewagon's Avatar
The left one.
Got pics? I dont recall a 2 wire knock sensor...
Old Jan 17, 2013 | 05:11 PM
big1000's Avatar
Haha on the left one...
I guess MudHippy knows a lot about these but from what I understand the 93 to 95 4runners have a two wire sensor. I will post pics tomorrow
Old Jan 17, 2013 | 05:18 PM
Lean something new every day!
That funny. I was in that deep on a 92 and a 95, just missed it. Haha.
Old Jan 17, 2013 | 05:27 PM
big1000's Avatar
The knock sensor actually adjusts the timing so if you have it bypassed your truck could be running much better, and you will have a pesky code 52.
Old Jan 18, 2013 | 08:26 AM
big1000's Avatar
So nobody knows the answer to this? If anybody knows what the two wires do then I could figure out which one goes to ECU and wire it in that way. There's one brown one and one black wire. I just need to know which one goes the ECU thanks
Old Jan 18, 2013 | 11:48 AM
ksti's Avatar
Originally Posted by big1000
so nobody knows the answer to this? If anybody knows what the two wires do then i could figure out which one goes to ecu and wire it in that way. There's one brown one and one black wire. I just need to know which one goes the ecu thanks
You should be able to click image to make it larger, it shows where brown and black wire go. Good Luck
Old Jan 18, 2013 | 12:24 PM
vital22re's Avatar
totally a bro
There is a signal wire and a ground wired for shielding of the signal wire. The signal wire is wrapped by the shielding wire.
Old Jan 18, 2013 | 02:22 PM
MudHippy's Avatar
Both types of knock sensor are 1 wire(for the sensor signal). Which is black for both types AFAIK.
88-91
92-95
From the 88 WD(see CONN S terminal 17).
Both types of knock sensor wires(the wires connecting the sensor to the wiring harness) are 1 wire on one end(sensor), 2 wire on the other end(wiring harness). So there's 2 terminals on the wiring harness connector(1 for the sensor signal wire, and 1 for the sheilding), and 1 terminal on the knock sensor connector(for the sensor signal wire...obviously).
88-91
92-95
Old Jan 18, 2013 | 03:22 PM
ksti's Avatar
So what you guys are saying that there is 2 wires that incorporate each other, thus making it a one wire sensor?
Old Jan 18, 2013 | 04:04 PM
vital22re's Avatar
totally a bro
ever cut a coaxial tv cable? it'll look similar to that. The o2 sensor wired In the engine harness are the same way.
Old Jan 18, 2013 | 04:13 PM
ksti's Avatar
Yes I have and now I understand it. Haven't had to replace knock sensor pig tail yet. Thanks
montanatruck
Feb 26, 2017 07:07 AM
nonstop
Jul 24, 2015 06:29 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
88yodabasket
Jul 13, 2015 01:32 PM
smiley52
Jul 11, 2015 05:16 AM
