Low Fuel Level/ Check Engine Light
Old Apr 17, 2007 | 05:02 PM
TEXAS~BACKROADS's Avatar
Question Low Fuel Level/ Check Engine Light
Ran a search didnt see this particular question answered. Truck runs fine all levels/temp/charge all good. The check engine light came on and the only thing I could determine is I ran the fuel level too low. This is the first time I have done so. So, could the low fuel level cause the "CHECK ENGINE LIGHT" to come on. I noticed no missing etc...when the light came on. Is this as simple as clearing the code?
Old Apr 17, 2007 | 05:12 PM
TNRabbit's Avatar
Check the codes: http://personal.utulsa.edu/~nathan-b...26diagnosi.pdf
Old Apr 17, 2007 | 05:21 PM
AH64ID's Avatar
the gasket on the filler cap might be worn out, this can cause the light to come on.
Old Apr 17, 2007 | 05:23 PM
Thanks....Will disconnecting the battery clear the initial code?
Old Apr 17, 2007 | 05:43 PM
MMA_Alex's Avatar
just pull the code. its free, its easy, and it'll tell ya whats wrong.
but, yes pulling the negative wire/efi fuse for a few mins will reset the code as well as the entire ecu.
Old Apr 17, 2007 | 06:17 PM
HAVOC's Avatar
I've seen one instance where running out of fuel caused a check engine light to come on. The code was for "engine running too lean".
Old Apr 17, 2007 | 07:06 PM
TNRabbit's Avatar
MANY things can cause check engine light to come on. You an reset the ECU by pulling the large EFI fuse under the hood; that way you don't reset any radio stations/codes/etc.
Old Apr 17, 2007 | 08:51 PM
Thanks guys....I like the fuse idea and didnt think of that route.
sonic concepts
Aug 16, 2025 03:13 PM
rbravo1
Jun 29, 2015 01:34 PM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
Dr. Evil
Jun 7, 2002 09:19 AM
