Name this part
Old Apr 9, 2007 | 01:02 PM
WFO's Avatar
WFO
Name this part
http://personal.utulsa.edu/~nathan-b...68cylinder.pdf
Look here for a sketch of it.
On the rear of the intake manifold there is the water bypass outlet and on this there is a plug of some sort (the one on the far pass. side) it has a rubber hose like a vacume line coming out of it.
What is it? The hose is broke off on mine
Old Apr 9, 2007 | 07:15 PM
toyota_mdt_tech's Avatar
Its a VSV or a vacuum switching valve. It allows canister purge when its warmed up. Its blue in color, 2 nipples and you broke one off when removing the pulsation dampner to disconnect the fuel line. Or someone else did. When you remove the pulsation dampner, pop off the plastic cap on it, then it wont break the VSV, and pop the cover back on when its tight. Dealers will have it in stock.
Old Apr 10, 2007 | 04:02 AM
WFO's Avatar
WFO
Yep one of the lines goes to the Charcoal canister.
Youre a genius!
88sasturbotoy
Jan 30, 2026 01:57 PM
May 20, 2016 10:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
akaphilly
Jul 9, 2015 02:34 PM
