Brake Problem? Please help, this is serious.
Old Apr 17, 2007 | 05:57 PM
Adawg_08's Avatar
Well my brakes were getting pretty bad. No brake unless you pumped it. So I put a new Master Cylinder on it. Bench bleed it really good and ran a quart of fluid thorugh all the lines. Same thing, you have to pump at least once to get much brake, then it still goes to the floor. Lines are good, no leaks, fresh fluid. What else could I do? I'm pretty sure that there is no air in the lines. I have a one man bleeder but still used 2 people. I will try gravity bleeding them tommorow, or I can get a hold of a power bleeder to try to. I bleed each wheel and the LPSV. I can't drive it because brakes are to bad.
What do think is wrong? Please help me.
Old Apr 17, 2007 | 06:05 PM
CJM's Avatar
CJM
Your brake booster is most likely bad.
However you check yor discs and drums out and they are fine right??
Old Apr 17, 2007 | 06:11 PM
UncleBob's Avatar
Rear Brake shoes adjusted 'till they scrub the drums, right?
Old Apr 17, 2007 | 06:14 PM
PoleVaulter95's Avatar
i have a similar problem so i cant wait to see what the out come is how do u know if your booster is shot or your shoes arent adjusting all the way?
Old Apr 17, 2007 | 06:20 PM
UncleBob's Avatar
http://personal.utulsa.edu/~nathan-b.../3checksan.pdf
http://personal.utulsa.edu/~nathan-b...tem/11-4wd.pdf
Old Apr 17, 2007 | 06:21 PM
gonzo's Avatar
X2
Misadjusted rear shoes will cause this.
I find the almost everytime I go wheeling, (mud, water) my rear shoes are out of adjustment.
Back off on the adjustment for your e-brake then adjust the shoes and readjust the e-brake cable
Good idea to pull the drums first and check the shoes and clean out any mud etc.
Old Apr 17, 2007 | 06:28 PM
uncle bob those are some great sites you posted i think the will help me out and hopefully they will help adawg 08 good posting
Old Apr 17, 2007 | 06:37 PM
UncleBob's Avatar
Here's the whole manual. Yota-tech is great, isn't it?
http://personal.utulsa.edu/~nathan-b...fsm/index.html
Old Apr 17, 2007 | 11:04 PM
jmach1's Avatar
When you say you ran a quart of fluid throught the system I am assuming you meant that you ran brake fluid through it. The reason I ask is that about 3 years ago, stupid me forgot how to read and put power steering fluid through the entire system. Could not figure out why my brakes sucked and that the brake reservoir cap kept falling off. Thanks to this forum, I figured out what I did and replaced almost everything. That is just my 2 cents and I hope that was not what you did. I really dont think thats what you did but it can and has happened.
JMach1
Old Apr 18, 2007 | 08:45 AM
Adawg_08's Avatar
I am pretty sure the booster is good though. I did that test with the engine off and the pedal got higher each time.
Old Apr 18, 2007 | 08:52 AM
91TPU's Avatar
pull the the brake booster vacuum line while its running, make sure nothings wrong there
Old Apr 18, 2007 | 02:42 PM
1994runner's Avatar
Did you put a new or rebuilt master cylinder on? I have seen MANY rebuilt masters that are junk out of the box
Old Apr 18, 2007 | 03:02 PM
Adawg_08's Avatar
brand new MC
Old Apr 18, 2007 | 07:29 PM
rajin's Avatar
here is how i bleed brakes and it works all the time.. 1) loosen bleed nipple, connect bleed hose & bottle to nipple. 2) have someone to depress brakepedel & keep holding. 3) now sqeeze calipers pistons in (make sure nipple is loosen, & clear) 4) brake pedel still depress, now tighten nipple. tip..try using clear bleeding hose so u can actually see what is comming out of the calipers.
hope this helps ....raj
Old Apr 19, 2007 | 10:04 AM
Adawg_08's Avatar
I'm sure there is no air in the lines though,
what did you mean by pulling booster line?
Old Apr 19, 2007 | 06:08 PM
rajin's Avatar
what i am saying that air might have been trapped in the calipers ..
one other thing, check plunger free play ie between master cylinder & booster (excessive free play will cause the brake pedel be low )
raj.
Old Apr 20, 2007 | 12:50 AM
ovrrdrive's Avatar
I've never had to manually adjust my reear brakes... They are auto adjusting.
By the way, if you have a new master cylinder and still have this problem it just about has to be either air in the lines or in the mc itself. Or possibly a ballooned rubber brake line or something weird like that.
Old Apr 20, 2007 | 02:14 AM
chopitrakeit's Avatar
Bleed the proportioning valve at the back too.
Old Apr 20, 2007 | 02:51 AM
1994runner's Avatar
Check to make sure the brake pads aren't sticking in the calipers. I have seen the slides on the sliding type of caliper get stuck and cause this condition. Basically the first pump pushes the pad to the rotor and second will give some brake feel. Make sure the pistons in the calipers goes back in the caliper easily as well and the pistons arent siezed... just a thought
Old Apr 20, 2007 | 11:08 AM
Adawg_08's Avatar
I took the new MC back to get a new one,
then ajdust the rear drums till' they scrub and calipers in the front,
then I guess bleed some more. get back to you in a couple days.
Thanks everybody.
