Compatible Rear Coil Springs
I'm looking for a compatible coil spring which can be cut to size for the rear coils springs in my 93 4Runner. I know it can be done with some Nissan's so I was curious if anyone has heard of this for the 4runner.
Thanks
Thanks
Are you trying to return it to stock height after sag? Or get some lift? I wouldnt want to go cut a set of springs unless I had no other option, and there are many options for the back of a 2nd gen
FJ80 Coils in Canada...no such luck! That's where my search started. Probably just gonna buck up and order the pro comps from a local shop.
Search for "cruiser coils" on here - they'll have the part numbers and everything you need.
There are several aftermarket coils ranging from 1.5" lift to 4" specificallly for the 2nd gen 4Runner and Land Cruiser lift coils will work too, but will be considerably over 4" (prob closer to 6")
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
terminator
07-27-2015 07:13 PM
Vargntucson
07-04-2015 12:15 PM
2nd, 3rd, 4runner, 95, 96, coil, compatable, compatibility, compatible, cruiser, gen, land, rear, spring, springs
