sway bar endlinks
Old Apr 15, 2007 | 12:26 PM
swerks's Avatar
sway bar endlinks
I have a 86 4runner, are there two nuts on the endlinks or is one a bolt head? I was able to remove the sway bar from my truck but cant remove the endlinks from the sway bar. Any Help
Old Apr 15, 2007 | 12:45 PM
2_86's's Avatar
sway bar links
The end link is just like one long bolt. If you already disconnected it from the lower control arm and it's still not coming apart-it's rusted together. They look like the one's here:
http://www.rockymountainsusp.com/SwayBarLinks.htm
That's where I got mine from and delivered quickly.
Old Apr 16, 2007 | 07:55 AM
Flash319's Avatar
Throw the sway bar in the garbage and run without it. The ride is much better and the body roll is not that much worse then with it.. This is the first thing to go when I get a new Toy.
Old Apr 16, 2007 | 10:21 AM
drew303's Avatar
or get quick disconnects if you wanna keep it.
Old Apr 16, 2007 | 11:34 AM
thook's Avatar
Soak it real good with some PB blaster for a couple of days. Then beat 'em out with a shop hammer...if they're really rusted badly.
But, keep it. It'll help keep the sucker from flipping if you ever have to swerve in an emergency. Get the disconnects if you want to wheel. Upgrade the suspension if you want a smoother ride....removing the sway doesn't make as much of a difference as that.
(I figured I'd add my $.002 worth...since others have.
ladybugRC
458
Aug 21, 2020 10:41 AM
A2theK
Oct 14, 2015 07:10 AM
Obmi
Oct 4, 2015 11:30 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
potatopants
Sep 15, 2015 06:26 AM
