Rear Shock Relocation
Old Apr 12, 2007 | 06:28 AM
Denk's Avatar
Is there any benefit to having the rear shocks relocated to an inboard position? Has anyone done this to their 2nd gen?
Older toys = / \
Newer toys = | |
Old Apr 12, 2007 | 06:39 AM
Marc P's Avatar
I have a similar post in offroad tech section....I am not sure a relocation bar will work with the coil/4-link setup found on 4runners.
Old Apr 12, 2007 | 07:05 AM
usmarinerecon's Avatar
I am about to do this to my 1st gen.... I will post pictures when the new hardware get's in and on... I also have a 5" suspention lift tho.
Old Apr 12, 2007 | 07:15 AM
Marc P's Avatar
You also have leaf springs.....
Old Apr 12, 2007 | 03:20 PM
Word!
Old Apr 12, 2007 | 06:29 PM
FredTJ's Avatar
Older toys = / \
Newer toys = | |
OUTBOARD and as close to vertical as possible is the way to go.
Not the other way.
We've been outboarding the rear shocks in later model (coil sprung) Jeeps ('96 forward) for a couple of years now and the difference in every metric that one would care to use to measure with is just outstanding.
- Shocks work the best mounted vertically.
- Outboarding a shock adds tremendous stability to not only the suspension but to the body (as in body roll) as well.
Front shocks are normally outboarded pretty much from the factory.
Rears seldom are.
Ford, in their P/U's started outboarding the rear shocks and even started running ads explaining why and the huge difference in ride that it produced.
You basically want the shock mounted as close to the wheel as possible.
In the Jeeps, we notched out the frame and welded in Ford shock towers and mounted the shocks basically outside of the frame, between the inside of the wheel and the outside of the frame rail.
That's not 100% accurate description as the shocks were mounted inside the frame rail to some extent.
Fred
Yotadawgjr
10
Aug 23, 2015 10:51 AM
terminator
Jul 27, 2015 07:13 PM
Massmayhem247
Jul 18, 2015 05:46 AM
icentropy
Jul 14, 2015 10:23 AM
akaphilly
Jul 9, 2015 02:34 PM
