damn squeeling is driving me nuts!
Old Apr 14, 2007 | 04:54 PM
FORCE FED DUB's Avatar
recently my 3VZE has started squeeling! it seems to come from the power steering pump (yes i checked the fluid level). when i turn the wheel it makes a groaning noise but that might be normal and i just started noticing it. is the pump going bad?
Old Apr 14, 2007 | 05:02 PM
keithguts's Avatar
Are you sure it is the PS pump. One way to find out for sure is to take off the belt conecting to the pump. This will tell you for sure.
Old Apr 14, 2007 | 05:05 PM
drew303's Avatar
squeeling? Tighten your belts up?? replace em?
Old Apr 14, 2007 | 05:19 PM
TNRabbit's Avatar
Check that the woodruff key hasn't come out of the pulley.
Old Apr 14, 2007 | 05:59 PM
MMA_Alex's Avatar
you did check the fluid level correct? they'll start to whine when low on fluid. Or it may have decided to become a ford...
Old Apr 14, 2007 | 06:17 PM
navyredneck's Avatar
I just changed the fluid on mine and it helped with the squealing. Are you using ATF?
Old Apr 14, 2007 | 06:25 PM
hogie9ll's Avatar
new belts and pullies, tenaturies pullies
Old Apr 15, 2007 | 06:35 AM
longhungsilver's Avatar
I second changing your fluid... use toyotas dextron II or III... thats a cheap fix if it works
bigjstang
Jun 2, 2025 03:56 PM
Whatever123
Sep 30, 2015 12:12 AM
redneck17
Jul 17, 2015 07:44 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
Cdn-wilderness
Jul 10, 2015 07:43 PM
