damn squeeling is driving me nuts!
Old 04-14-2007, 04:54 PM
FORCE FED DUB's Avatar
recently my 3VZE has started squeeling! it seems to come from the power steering pump (yes i checked the fluid level). when i turn the wheel it makes a groaning noise but that might be normal and i just started noticing it. is the pump going bad?
Old 04-14-2007, 05:02 PM
keithguts's Avatar
Are you sure it is the PS pump. One way to find out for sure is to take off the belt conecting to the pump. This will tell you for sure.
Old 04-14-2007, 05:05 PM
drew303's Avatar
squeeling? Tighten your belts up?? replace em?
Old 04-14-2007, 05:19 PM
TNRabbit's Avatar
Check that the woodruff key hasn't come out of the pulley.
Old 04-14-2007, 05:59 PM
MMA_Alex's Avatar
you did check the fluid level correct? they'll start to whine when low on fluid. Or it may have decided to become a ford...
Old 04-14-2007, 06:17 PM
navyredneck's Avatar
I just changed the fluid on mine and it helped with the squealing. Are you using ATF?
Old 04-14-2007, 06:25 PM
hogie9ll's Avatar
new belts and pullies, tenaturies pullies
Old 04-15-2007, 06:35 AM
longhungsilver's Avatar
I second changing your fluid... use toyotas dextron II or III... thats a cheap fix if it works
bigjstang
08-25-2021 12:41 AM
Whatever123
09-30-2015 12:12 AM
redneck17
07-17-2015 07:44 PM
HaydenConQueso
07-12-2015 05:22 PM
Cdn-wilderness
07-10-2015 07:43 PM
Quick Reply: damn squeeling is driving me nuts!
