A-arm and tire rub?
Old Apr 17, 2007 | 07:15 AM
GMJK86SR5's Avatar
A-arm and tire rub?
I have ball joint spacers and 33 inch tires on my 91 4runner. I have the stock steel rims that came with the 4runner. When I installed the BJ spacers, I trimmed the A-arm lip. Now, it looks like the A-arm is rubbing against the tires. I have a nice grove cut into the inside of the front tires. Any suggestions?
Mike
Old Apr 17, 2007 | 07:17 AM
elripster's Avatar
Mike
Wheel spacers or larger tires. What tires do you have now? I have 31X10.5's "Dominators" from Discount and they clear with quite a bit of room. I also have the stock alloy wheels.
Frank
Old Apr 17, 2007 | 07:19 AM
norcalsvx's Avatar
33x12.50 or 33x10.50??? my 33x10.50's dont rub at all
Old Apr 17, 2007 | 07:33 AM
Yota82's Avatar
I had that problem with a factory alloy too. I have used the Tacoma style wheels in the past and it solved it. Now I run the American Racing Outlaw II 15x7 (factory width). The offset is different and they clear just fine. When I had the wheels that rubbed, I noticed that they would only do it at the suspensions full droop. They were fine at ride height. I would try a different tire and wheel combo. Do your wheels happen to be the same ones as the truck in the pic below?
Old Apr 17, 2007 | 07:36 AM
GMJK86SR5's Avatar
I have 33-12.50. They worked on my 86 truck. i was using the 15x8, stock, aluminum, toyota wheels. Are the stock steel wheels any different? That is what I am using on the 91 4runner?
Mike
Old Apr 17, 2007 | 07:41 AM
GMJK86SR5's Avatar
Thanks yota82,
No, I used those alloys on my 86 pickup. I am using the stock steel toyota rims.
Old Apr 17, 2007 | 08:11 AM
AuburnRunner's Avatar
I have the same problem w/ my stock steelies. I have a set of 4runner alloys on the way that should fix it though... You could run wheel spacers like elripster suggested if you want to keep your wheels
Old Apr 17, 2007 | 08:47 PM
GMJK86SR5's Avatar
I looked at the Rims I have been using over the years and here is the run down. My 86 alloys are 7 inches wide. A pair of alloys I bought are 8 inches wide and the steelies are wider, maybe 8.5 to 9 inches wide.
The 33x 12.5 worked on the 86 with the 33's and bj spacers. The 33's with the steelies are rubbing at the upper a-arm. So my choices are to buy spacers for the steelies or switch the 33's to the 15x7 alloys. Any suggestions?
Mike
Old Apr 18, 2007 | 01:42 PM
Jay351's Avatar
I would buy spacers if you like the steelies, and if you dont really care, you could just go back to the 15x7 alloys.
Old Apr 20, 2007 | 09:09 AM
GMJK86SR5's Avatar
I do not want to put a 1 inch spacer on. I would like to know if I can put my 33's on my 15x7 alloys, and would that work with the 91 4runner? Are the A-arm setups on my 86 truck the same as the A-arms on the 91 4runner? I am a bit lost as to why the 33's are worked on the 86 and not on the 91 4runner.
I measured the back spacing on the two sets of alloys and they are 4.5. It that correct. The spacing on the steelies is 4.375, so not that different. Any way, I do not want to use spacers, and would likt info on which of the three sets of rims I have will work on the 91 runner. The 15x7 alloys or the 15X8 alloys with 33's. Thanks for any help.
Old Apr 20, 2007 | 09:12 AM
norcalsvx's Avatar
you can mount 33's on a 15x7, i've done it a few times at the shop
Old Apr 20, 2007 | 09:25 AM
GMJK86SR5's Avatar
Thx Norcalsrv,
Thats the info I needed. I think I will go that route. Do you think the 33's on 15x7s, would fit better(as far as a-arm rub), compared to the steelies and 33's. I think the back spacing is slightly less than the alloys, and the steelies look to be 8 to inches wide. Any know the actual size of the steelies?
thanks again Mike
BushPig
Oct 29, 2022 06:26 AM
djpg2000
Nov 11, 2020 04:56 AM
Jamie4runner2000
Jun 20, 2016 09:13 AM
Scatterbrain
Sep 3, 2015 06:46 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
