2WD grinding sound from front end.
Old Apr 16, 2007 | 03:16 PM
neatname's Avatar
I have an 86 4runner. While driving in 2 wheel drive a loud noise has developed, the sound then goes to a grinding noise. For the most part it is a constant noise, if I lock the hubs the noise goes away. I thought it was brakes, but the brakes are fine. Oh yeah the sound is only on the driver's side. Anyone have any ideas?
Zach
Old Apr 16, 2007 | 04:46 PM
Tdubbs05's Avatar
sounds like somethings grinding in the hub. makes sense that when it's they aren't locked, the wheels just spin around the axle. and when they are locked, the wheels are locked onto the axle. i don't know enough about hubs but sounds like something needs to be replaced/lubed.
Old Apr 16, 2007 | 05:34 PM
curtiswyant's Avatar
Could be a wheel bearing. I had the same problem. I would replace both sides because it's hard to tell where the sound is coming from. I would have sworn it was my driver's side, replaced it, and the sound didn't go away until I replaced the pass side!
Old Apr 16, 2007 | 05:37 PM
neatname's Avatar
Thanks guys for the responses. I'll let you know what i find out.
Old Apr 16, 2007 | 05:38 PM
Brenjen's Avatar
Wheel bearing most likely. Get it fixed quickly, if it's grinding it's near failure.
jasonty
41
Dec 23, 2018 01:00 PM
colasurdo
Jul 16, 2015 11:32 AM
hexrain
Jul 12, 2015 01:13 PM
mlavery85
Jul 12, 2015 10:33 AM
crashburnoveride
Jul 10, 2015 06:39 AM
