Why does it die? intake...
Old Apr 10, 2007 | 02:12 PM
thegreydog's Avatar
I decided to go and clean the TB... Immediately after I took the intake hose off, the engine stalled out. I have cleaned several in the past, but was able to remove the intake tube and spray it out. What stalls the motor out?
Old Apr 10, 2007 | 02:16 PM
TNRabbit's Avatar
The VAFM must be hooked up in order for the engine to work. Most newer engines have a MAF further downline in the intake. It won't run with the TB intake hose off.
Old Apr 10, 2007 | 03:03 PM
Firefightertaco's Avatar
on my 3.4l i got to let it warm up before i can take off the intake with out it stalling
Old Apr 10, 2007 | 05:53 PM
thegreydog's Avatar
Good deal, my old 85 would come off with no problem. Is there any air filter upgrades for this?
Old Apr 11, 2007 | 07:22 AM
jht3's Avatar
you don't mention what engine. if you pull a hose off behind the AFM, you have just introduced a HUUUGE intake leak that your ECU can't compensate for.
Old Apr 11, 2007 | 07:26 AM
TNRabbit's Avatar
Stick with OEM air filters; best protection for the money. The "cold air" intakes are a complete waste of time & money & just let more crap into your engine.
Old Apr 11, 2007 | 01:56 PM
thegreydog's Avatar
Good deal, I did not know that with the cam and header if I needed to introduce more air. The tube coming out of the air box seems awful restrictive....
Old Apr 11, 2007 | 02:20 PM
dcg9381's Avatar
There is a "door" in the airbox that's probably more restrictive than the tube... Can't do much about that door unless you go to a different AFM.
Old Apr 11, 2007 | 03:15 PM
thegreydog's Avatar
That's what I think I am talking about, the arm that comes off and goes into the grill in the front. It just seems to be so restricted going into the grill where there is not a lot of air coming in, plus it's turned down..
Steven.m.paulk
Jun 7, 2020 10:45 AM
shisha1999
Mar 3, 2016 07:09 PM
Chicken12
Oct 14, 2015 03:54 PM
Rcbc92
Sep 26, 2015 03:00 PM
