Ticking from the engine compartment...
Old Apr 17, 2007 | 06:07 AM
monst's Avatar
Unhappy Ticking from the engine compartment...
My runner is ticking from the engine compartment...
I'm curious whats causing it, I was hoping maybe someone could rule out some things with my description...
It ticks only when there is load, when I am out of gear and rev the engine there is no ticking. Only when I am accelerating in gear... I'm told it could be an exhaust gasket, or valve clearance needing to be adjusted... it's a 95, 3vze, 3.0L... any help would be appreciated... what do you recommend I do, I'm not a mechanic. Do places do free diagnostics?
Also anyone have recommendations for mechanics in the Williamsburg/Newports News Virginia Area?
Old Apr 17, 2007 | 06:13 AM
TNRabbit's Avatar
if it's only under load, it could POSSIBLY be a rod bearing beginning to go. Unless the ticking you're describing is spark knock, in which case your ignition timing is advanced too much.
Old Apr 17, 2007 | 06:22 AM
monst's Avatar
its not a knock... its definitely a tick.. I'm gonna see if i can find something to record the sound maybe that will help
Old Apr 17, 2007 | 07:02 AM
TNRabbit's Avatar
the injectors on these engines tick like crazy.
Old Apr 17, 2007 | 07:32 AM
monst's Avatar
I'm pretty sure thats the problem... I had 4 injectors replaced recently.. is it ok for them to tick... or does it need to be looked at?
This makes the most sense since it every time alot of fuel is going to the engine.
Old Apr 17, 2007 | 07:53 AM
TNRabbit's Avatar
Mine have ticked since I bought the truck in 2000 w/ 92,000 miles on the odo. I sent them all off for cleaning recently (www.witchhunter.com) and they all came back with a clean bill of health.
I'm curious what they charged you for injectors; they are like $190 eaach from the dealer!
Old Apr 17, 2007 | 08:12 AM
monst's Avatar
$184.56 for 4, they gave me $47 back when i gave them my old ones. advanced autoparts
Old Apr 17, 2007 | 08:29 AM
TNRabbit's Avatar
Were the injectors you got rebuilt OEM? That's cheap for 4.
Old Apr 17, 2007 | 08:32 AM
monst's Avatar
to be honest im not sure, my brother in law did the work and ordered them.. so they where probably refurbished
Old Apr 17, 2007 | 09:52 AM
monst's Avatar
Exclamation
Heres the wav file of the sound... Listen to the whole file you will be able to hear it. you might have to turn up your speakers
http://www.piratesversusninjas.org/files/090601_01.wav
Old Apr 17, 2007 | 10:00 AM
TNRabbit's Avatar
I hear what sounds like an exhaust leak...
Old Apr 17, 2007 | 10:56 AM
monst's Avatar
are exhaust leaks important to fix?
Also it hard to listen to the engine to find the leak since the truck has to be moving... =(
anyone have a 3zve exhaust diagram?
Old Apr 17, 2007 | 01:36 PM
AuburnRunner's Avatar
I'm gonna agree with the exhaust leak diagnosis...
Check the x-over pipe and Ydown pipe where the two sides come together.. maybe even a bad exhaust gasket
Old Apr 17, 2007 | 01:57 PM
CJM's Avatar
CJM
Exhaust leak, or a vacuum line is broken/came off.
To check for an exhaust leak get some seafoam, it will smoke like crazy outta the exhaust and you can find it this way. It also cleans out engine gunk..
Old Apr 17, 2007 | 02:25 PM
yotawheelin95's Avatar
i got the same thing with my 95 3vze it jsut started with 150k on it
Old Apr 17, 2007 | 02:44 PM
Chrisnxl185's Avatar
My 94 V6 4runner makes the same sound. Are you saying the ticking is an exhaust leak? OR is that just something else you heard?
Old Apr 17, 2007 | 02:48 PM
TNRabbit's Avatar
Most 3vze ticking is simply injectors; I don't know about the 22re. The wav file he posted sounded like an exhaust leak to me.
Old Apr 17, 2007 | 06:22 PM
zbadboy69's Avatar
4x of the exhaust leak. Is it more noticeable when it is cold? Most exhaust leaks, especially exhaust manifold leaks, are louder when it is cold. When the vehicle warms up and things expand, the leak is often less noticeable. From what I can tell it sounds like an exhaust manifold.
Jeff
Old Apr 18, 2007 | 05:14 AM
Joey's Avatar
My 87 does it and its a leak about an inch long in the front of the ex manifold. Im scared to try and change it and break the bolts off. 2 of 3 are on the heat shield as it is.
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
cars-guy
Jul 11, 2015 07:51 PM
smiley52
Jul 11, 2015 05:16 AM
Gamble_STi
Jul 7, 2015 07:54 PM
