replacing rotors on a 91 runner
Old Apr 8, 2007 | 05:23 PM
gametom's Avatar
ok i want to star this by thanking every one for all the information i have gotten from this form. i have another question for you all i have to replace my brake rotors and it looks like it's all incorporated in to the hub can any one tell me what i need to have on hand to do this job and possibly even a step be step walk thro on how to remove the rotor
Thank you
Old Apr 8, 2007 | 05:33 PM
TNRabbit's Avatar
check the fsm here: http://www.toyotanation.com/forum/t99418.html
Basically, you'll need to beat the living hell out of the old one to get it off.
Old Apr 8, 2007 | 05:46 PM
1994runner's Avatar
Unbolt the 2 caliper bolts... 17 millimeter if memory serves me. leave the brake line attached and have a bungee cord handy to support the caliper and keep the weight off the line.
To remove the rotor you will have to disassemble the hubs. Not a very difficult job, have a rag or tray clear and lay the parts out in order of removal. to reinstall reverse removal process. Also do one side at a time to have visual reference if you get stumped. Any questions pm me
Old Apr 8, 2007 | 05:54 PM
Elton's Avatar
http://www.4x4wire.com/toyota/mainte..._end/teardown/
http://www.4x4wire.com/toyota/mainte...nd/reassembly/
Old Apr 8, 2007 | 05:55 PM
91_4x4runner's Avatar
I used two zip ties to secure my calipers to the upper a-arm, but it works just as easy. Assuming you only have ADD hubs, you just pry the cap off and remove the center hub bolt (12mm I think). You then pull off the hub (1 piece) and are faced with a huge spindle nut and spindle nut bearings. (54mm)... They look like this basically:
Then, the hubs pull straight off.... It isn't brain surgery by any means.... Make sure you tighten up the studs and everything real good.... May as well replace the pads while you are at it....
Old Apr 8, 2007 | 06:04 PM
gametom's Avatar
so do i need to replace the wheel bearings or just the seals?
Old Apr 8, 2007 | 06:20 PM
dirtoyboy's Avatar
check condition of bearings and seals...if they need to be replaced, replace them. i would recommend using only toyota rotors for quality reasons but hey theyre your brakes
Old Apr 8, 2007 | 06:24 PM
Make sure you pack that sucker full of grease too.... There's a tool someone made on here called a spindle lubricator... I suggest you check it out.
voiddweller
19
May 2, 2016 09:10 PM
miceal383
Jun 29, 2015 12:27 AM
Iceman4193
Jun 28, 2015 10:30 AM
YotaGreenhorn
Jun 27, 2015 07:00 AM
stretch786
Aug 3, 2005 02:17 PM
