1986 22RE ignition system question
Old May 8, 2023 | 04:21 AM
Plarpy's Avatar
Question 1986 22RE ignition system question
Hi, new to this site. I recently acquired a basket case '86 4Runner that I am in the process of resurrecting. Over the years it has had engine swaps (apparently) and someone swapped out the engine harness and ECM (with wrong parts). Anyway, missing a lot of hard to find parts to make it run correctly. Plus the harness was in horrible shape. Long story short, I am going to convert it to a carb setup. I have already removed the cobbled up fuel injection equipment and weeded out the mangled up wiring harness - only leaving behind the essentials from the body side of that harness (starter, a/c, oil and temp gauges, backup lights, etc).
My question is this - even though this is a very early fuel injection set up, it did have a knock sensor. During my weeding out of the harness, I un-pinned and removed everything that originally terminated at the ECM. Included in that bundle was a 3-wire pigtail that went all the way over to a green, round 3-wire plug that connected to the igniter on the ignition coil. I tested everything after I got finished with the harness - everything works, including power to the coil when the key is on. What is going to be affected by the absence of that 3-wire connection to the igniter from the ECM? I assume that's knock sensor input. But will the ignition system still function and provide timing advance with that disconnected? If it IS going to be a problem, what are my options?
Thanks in advance. I'm hoping someone knows these answers.
Old May 8, 2023 | 07:04 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Are the three wires black, with either a red, yellow, or white stripe?
If so, they're just for EFI.
Old May 8, 2023 | 07:06 AM
Plarpy's Avatar
Yes. All three were black, seems like one had a red stripe, one had a yellow stripe and the 3rd one may have been all black - or possibly had a white stripe. I'm at work now, can't confirm.
Old May 8, 2023 | 08:05 AM
Plarpy's Avatar
...they're just for EFI.
I'm aware - I de-term'd them from the ECM connector. My question is how will this affect my ignition timing advance? Does the ECM control it or does it only retard it when there's a knock sensor input?
Old May 8, 2023 | 12:54 PM
millball's Avatar
You need a vacuum advance type distributor from a carb engine.
The EFI distributor will not be satisfactory.
Old May 8, 2023 | 02:03 PM
Plarpy's Avatar
Thanks for the input.
Old May 14, 2023 | 10:12 PM
AnnaManning's Avatar
Have you found your answer?
Old May 15, 2023 | 12:56 AM
Plarpy's Avatar
not definitively. But I’ll have it running soon and that I’ll know for sure.
Old May 15, 2023 | 05:13 AM
Ok
Old May 25, 2023 | 07:22 PM
Plarpy's Avatar
Finally got this thing running today with the carburetor set up. It runs fantastic but as I suspected there is no spark advance. The ignition timing is just constant. I have it set around 17° and it’s fairly drivable but I am going to put an earlier style, vacuum advance distributor in it.
Old Jun 20, 2023 | 04:33 AM
MichealBrower's Avatar
Thanks for the video. I appreciate you for sharing that video with us. I was searching for it for my friend and I am glad I found your post where you have shared a video link with which I can share it with my friend. I always try my best to help my friend because he is the only friend I have whom I can trust. He also always helps me. Recently, I was facing a financial problem and he recommend the Gamblingorb GR and also explained to me how can I win real money by playing online real money games. He also shared a link with me where I found those sites where I can play online real money games and can earn money by winning those games.
outdoorjunky
Jan 22, 2021 11:26 AM
rushw
Oct 3, 2015 12:37 PM
tshort48
Sep 27, 2015 01:04 PM
