Leaking water pump
Old Apr 25, 2023 | 04:47 PM
Omak90truck's Avatar
Question Leaking water pump
I recently had to replace the timing belt and fan bracket on my truck (1990 Reg Cab DLX 4wd 3VZE). I installed a new Aisin water pump at the same time, but there's been an intermittent coolant leak since then. Coolant was clearly coming from around the water pump or thermostat housing, so I went back in and replaced the gaskets twice with no improvement. I finally used some dye and found the leak was coming from the factory plugged outlet for the oil cooler (which my truck doesn't have). I really don't want to go back in and pull the water pump yet again. Does anyone know of a way I could seal that plug without removing it? I thought about teflon tape, or soldering the hole. I even considering JB Weld but I don't think it would hold. I know I can get the pump replaced, but that would take a week and I need the truck sooner. But, I'm not so desperate that I'll try something that'll break in a few weeks/months. Any ideas? Suggestions?
Old Apr 26, 2023 | 07:01 AM
Jimkola's Avatar
YT Community Team
5 Year Member
That's a decent sized pipe, and it's pressed in.
My thoughts would be to either tap the hole and put in a bolt with thread locker, or fill the hole with melted down aluminum stick rod.
If that plug blows out completely it'd drain your system in seconds.
jrtredo
Mar 14, 2017 04:35 AM
Amnesiac
7
Nov 20, 2012 01:55 PM
customdrumfinishes
Oct 2, 2010 02:47 PM
CenCalRunner
May 6, 2007 05:39 PM
spacewrangler
11
Sep 13, 2005 03:10 PM
