dealer tells me my water pump leaks....sometimes.
Old Sep 13, 2005 | 12:06 AM
spacewrangler's Avatar
and sometimes it doesn't? what is that supposed to mean? how can it leak sometimes? they are trying to get me to replace the water pump and timing belt for $650.00 but i'm not sure i want to spend that kind of money if it's not needed just yet.
if the pump is leaking sometimes, shouldn't i see some coolant leaking from somewhere? ..or is the pump totally concealed by all the plastic on the front of the engine?
Old Sep 13, 2005 | 12:30 AM
AW1090's Avatar
is it not covered under warranty?
Old Sep 13, 2005 | 12:32 AM
not at 86k miles.
Old Sep 13, 2005 | 12:35 AM
AW1090's Avatar
wow....that's a ton of miles for two years..I don't see how it could leak only sometimes. It either leaks or it doesn't.....do you have another place you can get an opinion from on it or is it already torn apart?
Old Sep 13, 2005 | 12:38 AM
jimbo74's Avatar
some leaks are dependent on temperature or a lot of otehr factors, i do see it being possible it leaks sometimes
Old Sep 13, 2005 | 12:44 AM
AW1090's Avatar
yeah....I guess I could see that.....you mean as seals and things swell and shrink with temp...right jim? Sorry, just trying to learn while trying to help
Old Sep 13, 2005 | 12:54 AM
thanks for the replies. ....i guess i can see how it would leak sometimes. ..but the way the service advisor explained it to me made me think they just had it up on the rack and it was just sitting at idle. ..he said "sometimes it was leaking, sometimes it wasn't"
i've decided to get a 2nd opinion. ..i know i can get the pump and belt changed for less $$$$$ than they want at the dealer anyway.
Old Sep 13, 2005 | 06:55 AM
iaonbb's Avatar
You're due to replace t he timing belt anyway, and the water pump should be changed then as well so it might be a moot point? Trust me on this, the prior owner on mine didn't change the water pump when they did the belt and I just spent $600 to replace it at 130k when it would've only costy another $100 or so to do earlier and no extra labor. I'd say just do and then you don't have to worry about either for an other 100k or so... just my .02...good luck
Old Sep 13, 2005 | 06:56 AM
iaonbb's Avatar
bound to cover just a little more ground... ;-)
Old Sep 13, 2005 | 07:41 AM
noahrexion's Avatar
I say DIY for 1/3 the price!!!
Old Sep 13, 2005 | 01:08 PM
surf4runner's Avatar
...at least im enjoying the ride
Old Sep 13, 2005 | 03:10 PM
Ironmike4x4's Avatar
On the nose there Jim. I don't know if Toyota's water pumps are the same but GM waterpumps have "weep holes" in them so you can't confuse yourself with that, but it shouldn't pour when it leaks. Look to see if your hood is a bit wet has has been wet and you will know if it's leaking for sure or not.
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
Snort
Jul 19, 2015 07:03 AM
TammyMarie
Jul 15, 2015 11:14 AM
Jonny246
Jul 12, 2015 04:51 AM
