Auto Transmission Rebuild
Old Jul 18, 2023 | 02:45 PM
DrCreosote's Avatar
Hey all,
I have a 1990 4Runner 3VZE automatic and it's been running pretty good until the "Toyota rumble strip" started happening a few days ago. I put some shudder fix in it and it helped, but the problem isn't going away completely. I suspect the extreme heat in central CA is exacerbating any pre-existing condition, but it still exists so it needs to be corrected. My most basic plans are to do a fluid flush and filter change this weekend, but it's also in my mind to start planning to rebuild the transmission, but my only experience with the insides of automatic transmissions is with GM TH350, and I did a 700R4 once, but I wasn't there when it was finished. I've found rebuild kits online for not too much, but I am hoping to hear from someone who has experience with these components, especially if you can compare the difficulty working the innards of the TH350 vs. the Toyota gearbox. And perhaps other parts that should be replaced that aren't in the kits, or perhaps a good book I should get as a go-along. I'm not in an urgent situation right now, just looking a little bit forward, but it's an old car and stuff was probably worn out when I got it, but it keeps going anyway.
ThanX in advance.
Old Jul 24, 2023 | 07:57 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Did the fluid change help?
How did the old fluid look/smell?
Old Jul 24, 2023 | 10:15 AM
DrCreosote's Avatar
The fluid change got delayed because no one in town had the filter/seal kit so I had to order it. The fluid looks and smells good, not burnt,at the dipstick, so there is that advantage.
Old Jul 24, 2023 | 11:21 AM
Jimkola's Avatar
YT Community Team
5 Year Member
The trans and transfer they put on the earlier 4Rnrs were pretty durable.
X_Timbo_X
Nov 23, 2009 05:18 AM
toyotatom93
Jul 29, 2009 11:20 PM
95_4MuddinSr5
Sep 5, 2008 12:30 PM
Stump1883
North Carolina
15
Dec 4, 2004 10:40 PM
chasmc2
Apr 7, 2004 07:56 PM
