3.0 swapped with the 3.4
Old Jul 27, 2023 | 09:08 PM
tnumerick's Avatar
Hi everyone,
i need a a little help my 1995 4 runner we just swapped the motor from a 3.0 to 3.4 it’s out of 2000 runner what I need to know is how come it’s just cranking but it’s not turning over I know it’s something simple a sensor or something like that because the engine sounds amazing as it’s cranking, but it still won’t turn over any ideas ????
Old Jul 27, 2023 | 09:46 PM
Robert m's Avatar
Answering this directly and accurately will be pretty difficult as no one on here has had eyes on it but you. So, I'd start with the basics...
Do you have fuel at the rail? Are the injectors firing when you crank it?
Do you have spark?
Did you use an adapter harness or cut and splice?
Is everything electrical connected?
Is everything grounded correctly?
Intake tubing and MAF connected?
Old Jul 28, 2023 | 04:10 AM
rattlewagon's Avatar
Pull the check engine codes, Im sure theres some. That may point in the right direction.
Old Jul 30, 2023 | 01:36 PM
akwheeler's Avatar
My crystal ball says it is either fuel or spark.
divide your possibilities in half, give it a shot of starting fluid to see if you are getting spark.
if it starts and dies you need to diagnose fuel delivery issues, if it doesn't you aren't getting any spark.
Valvoman
Aug 8, 2015 03:52 PM
toytlle95
Mar 24, 2013 06:46 AM
-4_Runnin-
Jan 30, 2009 10:14 AM
4runnerwitsubs
3.4 Swaps
9
Oct 2, 2007 11:35 PM
