Power window issue
Old May 18, 2023 | 10:46 AM
8lgdspider's Avatar
Power window issue
Power window on passenger side goes down but not up. Have power to the plug and a new window motor but no go. ? 1989 pickup
Old May 18, 2023 | 06:22 PM
scope103's Avatar
The circuit for your power windows should look something like this (this is from a '93 EWD):
First, can you hear the motor straining to lift the window? If so, the electrical is probably okay, but you have a mechanical issue.
Next, does the window go down-but-not-up from both switches? The motor reverses just by reversing the polarity. Reverse the leads to the motor (you may need to use jumpers) and see if your down-but-not-up changes to up-but-not-down. Note that movement of the passenger side window requires cooperation of both switches; you'll need your multimeter to track down which one it is if it is a switch issue.
andlours
Nov 27, 2011 02:51 PM
eighty5yota
Dec 21, 2009 11:19 AM
gary96360
Feb 6, 2009 10:10 PM
4everunner84
Mar 21, 2005 11:52 PM
