Should I rebuild my W56?
Old Jul 2, 2024 | 06:51 AM
luke56's Avatar
A few months ago I made an introduction post on here about my 94 Toyota pickup project, progress has been slow due to work and school but I’ve made some progress. I have my transmission and transfer case dropped and I’m going to replace all the gaskets. The transmission has 150000 miles on it and is in good condition. While it’s opened up should I replace my bearings and maybe my syncros or should I leave the inner assembly together and just change my gaskets. It would be nice to not have to do anything but change gaskets but if y’all think it’s worth it then I might rebuild it. Thanks!
Old Jul 2, 2024 | 07:37 AM
mechkw's Avatar
If you're taking it apart to do the gaskets I would rebuild and freshen it up at the same time and not have to worry about it for quite a long time
Old Jul 2, 2024 | 02:36 PM
Jimkola's Avatar
YT Community Team
5 Year Member
Bearings are a consideration. If you have oem synchro rings and they’re in good shape I’d reuse. Marlin Crawler often had great prices on bearing kits, and they typically only use Japanese.
Old Jul 3, 2024 | 06:16 AM
luke56's Avatar
Reckon I’m going to change my bearings then. thought I was gonna catch a break on this one hahaha
Old Jul 3, 2024 | 06:44 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Well, it's a tough call. 15,000 miles isn't a lot. But it also depends on the bearings installed at the last rebuild. I'm a firm believer in Koyo and Naichi quality.
And the fact that the seals and gaskets only lasted 15,000 miles makes inspecting the bearings a good idea.
Old Jul 3, 2024 | 07:13 AM
luke56's Avatar
I called them and they said they didn’t sell their bearings, do y’all know any reputable company’s that sell a bering kit for my trans and transfer case? I want something that’s going to last because I don’t want to have to open my trans again for a long long time.
Old Jul 3, 2024 | 07:16 AM
luke56's Avatar
I’m so sorry, I just realized I mistyped it, I meant 150000, and the seals didn’t fail, I’m just overhauling it because I might as well while it’s out. Once this project is done I want to take a break from working on it so I’m trying to make it as realizable as possible and build it to last
Old Jul 3, 2024 | 07:20 AM
Jimkola's Avatar
YT Community Team
5 Year Member
If you post up your model number and production date I can look. 150,000? I’d absolutely do bearings while you have out.
you'll find both on the vin plate in the driver's door jam. the model number is typically at the bottom of the plate. something like RN101L-TRMDEA ( this is just a random example)
I only like using the best quality I can, and I'm cheap. So this often means I wait a bit for stuff to arrive.
Edit: got to thinking. Odds of a 30 year old/150,000 W56 having original bearings is rather low. Question is, when were they replaced, and with what brand? So if it were mine I'd probably replace just to not worry.
nix84yota
Jun 20, 2012 01:49 PM
surferkid26
Jul 12, 2009 09:26 AM
linuxrunner
Apr 12, 2008 07:00 AM
RustBucket
Feb 11, 2008 05:48 PM
Old Yotaler
Jan 23, 2005 01:12 AM
