Should new pilot bearing slide on input shaft?
Old Nov 19, 2024 | 09:26 AM
ATVTRAILRIDER's Avatar
I am putting a new engine in my '95, I ordered a new Asin clutch kit, it has a brand new Koyo bearing in the kit, the issue is that when I attempt to slide the bearing on the input shaft it only goes on about a quarter inch, I am thinking this should slide all the way on the input shaft, correct?
[img alt="This is as far as it will go.....
"]https://cimg4.ibsrv.net/gimg/www.yotatech.com-vbulletin/2000x926/20241118_220236_25b380234439ac118f9870f7c69a4b04ac fad6f3.jpg[/img]
Old Nov 19, 2024 | 06:56 PM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
You've not got an answer yet, so I'll be first to show my ignance.
The pilot bearing = that goes into the flywheel - supports the very small necked down part of trans input shaft. So yes, your bearing must fit over the smaill pointy part of input shaft.
Unless I'm totally missing what you're asking.
Old Nov 19, 2024 | 08:09 PM
millball's Avatar
Shouldn't take more than a little dressing of the tranny snout with some moderately fine carborundum paper to permit the bearing to pass.
Old Nov 20, 2024 | 10:02 PM
2ToyGuy's Avatar
If you aren't sure about your inpt shaft, try running your fingernail, if you have any, down each groove on the input shaft, and feel for burrs/anything sticking up. Same with the bearing. Don't use a dental tool. Not sensitive enough. If you can't use your finger nail get your wife or girlfriend, or both, to help Generally, they get a kick out of helping mechanic husbands/boyfriends do something mechanical, especially on a vehicle they use, even on occaision.
Pat☺
Old Nov 21, 2024 | 03:15 AM
mechkw's Avatar
Yes it should freely slide on the shaft with about 2-3 thousands clearance. It is there to support the front of the shaft from the weight of the clutch disc while shifting
rwas
Aug 25, 2024 02:37 PM
TruckeeToy
Jan 7, 2011 07:32 PM
wilshire
Apr 30, 2010 06:00 PM
slothman
Dec 18, 2008 11:13 AM
