3vze vibration when accelerating
Old Jun 3, 2024 | 07:48 PM
3.slow_lucas's Avatar
i just got back from vacation after letting my 95 4runner sit for 2 weeks, my moms alternator went out so she had to use my rig once or twice, so after i got home i did my first ever tune up. cap, rotor, and wires as well as a new o2 sensor. the plugs still looked okay and fairly new so i didn’t worry about replacing them. my problem is, however, that i feel like maybe i did something wrong, because before i went on vacation it wouldn’t vibrate so badly rolling down the freeway. i do notice a slight lack in power as well, it doesn’t get up and go quite as well as it used to. i’ve heard about it possibly being the rear U-joint since it only vibrates when i’m on the gas and it doesn’t do anything when i’m idling and giving throttle. this would be my first U-joint replacement if it is indeed that and what tools would i need? or could i have done something wrong during the tune up? thanks.
Old Jun 3, 2024 | 09:05 PM
Robert m's Avatar
Recheck you have the plug wire order correct and that they are all seated on the sparkplug and cap all the way
Old Jun 4, 2024 | 03:57 AM
so i put my vehicle into reverse then drive a few times and it makes a clunk only when put in drive. i put it in neutral and wiggled my driveshaft, to no surprise it’s my rear u joint failing
Old Jun 5, 2024 | 02:41 AM
ev13wt's Avatar
5 Year Member
If you replace the u-joints and it's still doing it - it's the slip link. I need greasing every 6 months. In mine it was the cause for the failing u-joint in the rear. Replaced it like three times before I figured it out.
Hsnow
Mar 27, 2024 08:44 AM
dansouthwick
Jun 7, 2014 12:02 PM
BigUnit118
May 6, 2009 07:03 PM
fredtheturd
Oct 28, 2008 08:07 PM
designrtx
Oct 31, 2005 06:12 PM
