Vibration during acceleration
Old May 6, 2009 | 02:28 AM
BigUnit118's Avatar
Here's my dilema got my first yota about a month ago. 95 v6 automatic. Last week i noticed vibration whenever i accelerated. The truck needed it regardless so i replaced plugs, wires, cap and rotor and fuel filter with no success. I did a little research and it pointed to my u-joints. I noticed to in my owner manuel and on my driver side sun visor there is a routine maintenance schedule for u-joints. I just want to know if i am on the right track any help would be greatly appreciated. thanks, Eddie
Old May 6, 2009 | 04:11 AM
jason191918's Avatar
Looks like you might be. I've heard that if they start vibrating, grease will no longer help you. Grease is a preventative, not a savior.
Old May 6, 2009 | 05:02 AM
TNRabbit's Avatar
Definitely sounds like a U-joint.
Old May 6, 2009 | 05:47 AM
cubuff4runner's Avatar
X3 on the u-joint. They are simple to check, just try moving them side to side. If there is any play they are bad.
Old May 6, 2009 | 05:55 AM
TNRabbit's Avatar
It's not always that easy. Set e-brake, & with tranny & t-case in neutral, rotate & pull the drive shafts STRONGLY & listen/feel for play.
Old May 6, 2009 | 06:43 AM
How are you going to rotate the drive shaft with the rear tires on the ground and the e-brake on? If it is doing in on accelleration day to day I am guessing it is the rear shaft not the front since it isn't spinning.
Old May 6, 2009 | 06:44 PM
BigUnit118's Avatar
Thanks people. I appreciate the replies. gonna take a better look this weekend when i have time. I didnt notice any play in the shaft but i checked it while in park.
Old May 6, 2009 | 07:03 PM
abecedarian's Avatar
even checking in park isn't a bad thing. you're looking for slop in the u-joints after all, not in the park pawl, etc.
You're looking to see if you can rotate the driveshaft itself more than you can move the output shaft of the trans / t-case and input to the rear diff and see any play there.
Flightguy
Oct 2, 2015 05:34 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
